Author Topic: What would cause my wheel studs to break while driving  (Read 8272 times)
Offline jfkelley
« on: November 19, 2019, 08:52:09 pm »
So my son is driving my 76K10 4x4 until his 77 Trans Am is done being restored  , One day he came home from school said dad the truck is pulling hard to the passenger side ..I was going to put new brakes on it anyways , Jack it up and wheel falls right off , all 6 wheel studs and Lug-nuts gone some damage to rim ...So I go get new Studs lug-nuts , bearings and seals , replace it all , put wheel back on torque down lug nuts and within 5-6 miles all lug-nuts gone but one , no studs broken off ...What is causing this! I’m about to pull my hair out !
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Offline DanMcG
Re: What would cause my wheel studs to break while driving
« Reply #1 on: November 20, 2019, 04:54:45 am »
Any issues with your neighbors? I can't see how 4-5 lug nuts could back off in a few miles.
Offline jfkelley
« Reply #2 on: November 20, 2019, 07:56:26 am »
No issues with neighbors ...Im just wondering if I’m using the wrong lug nuts Or the wheels have the seat wore out so the lugs can’t tighten up and seat properly.?? I’m at a lost
« Reply #3 on: November 20, 2019, 04:22:43 pm »
In the first instance, "someone" probably hit something. In the second instance, you replaced the studs, how did you seat them?
Offline jfkelley
« Reply #4 on: November 20, 2019, 09:23:14 pm »
I pounded them in with hammer and punch
Offline roundhouse
« Reply #5 on: November 22, 2019, 06:32:43 am »
If the lug nuts  get loose the studs will break off
When you tighten down the Lug nuts Check the wheel , make sure it’s fitting on the hub properly and is seating
And that the bolt holes are not damaged
If the holes on the wheel are egg shaped , the nuts will not stay tight
I would also replace the nuts
Offline fitz
« Reply #6 on: November 22, 2019, 01:05:44 pm »
How long have those rims been on the truck?
Any good pics of the rims & lug nuts?
Offline JohnnyPopper
  • Old Goof
« Reply #7 on: November 22, 2019, 01:44:48 pm »
Sounds like you did not seat them well enough and as you drove it, they seated themselves and loosened up and broke again.
There are splines on the studs that have to be seated completely into the rotor.
1980 C-10 under construction
