Author Topic: What are these wires?  (Read 12011 times)
Offline 82apache
« on: December 23, 2019, 09:42:45 pm »
82 K20   Left of the brake booster and through the firewall, 2 wires 1 green and 1 pale yellow or white, stuck together like speaker wire. In the cab they appear to run up behind the instrument cluster, in the engine bay the other end dives into the plastic wire loom down by the frame that also houses the Rear Intermediate harness.
I don't have them on my '79 nor my '86.  Any clue as to what they are?
And Merry Christmas!
Re: What are these wires?
« Reply #1 on: December 23, 2019, 11:13:47 pm »
Post a pic, please.
Offline 1984Texaswidebody
« Reply #2 on: December 24, 2019, 04:40:42 am »
Maybe the backup light and turn/hazard signal bulb.
Offline 82apache
« Reply #3 on: December 24, 2019, 09:09:18 am »
This morning a buddy of mine said it might be for the reverse switch. --700r4
Does that ring a bell?
« Reply #4 on: December 24, 2019, 12:09:56 pm »
No.
Sounds like something someone added, trailer brake etc.  but
Post a pic, please.
Offline 82apache
« Reply #5 on: December 25, 2019, 05:31:45 pm »
This is not a pic of mine but it appears to show the same wire combo.  The routing seems to be different as well but mine has been molested so that might account for that.  I am looking at a wire combo that has something to do with the fuel tanks?
The yellow-green combo roughly center of the pic
http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=136170&stc=1&d=1113932884
Offline 82apache
« Reply #6 on: December 25, 2019, 05:42:59 pm »
No.
Post a pic, please.
I considered that however the plug/grommet thing where it comes through the firewall appears to be factory and there is no evidence that a brake controller was ever mounted to the dash.
Offline JohnnyPopper
  • Old Goof
« Reply #7 on: December 26, 2019, 01:18:27 pm »
Flux Capacitor?  8)
1980 C-10 under construction
Offline 82apache
« Reply #8 on: December 27, 2019, 01:53:17 am »
Flux Capacitor?  8)
Hmm  I don't think so but with an old truck it is always hard to tell what all a PO has been doing with the wires. lol
Offline MIKE S
  • Member
« Reply #9 on: December 27, 2019, 10:51:33 am »
Do you have dual fuel tanks? That may be the harness for the sending unit.
Offline 82apache
« Reply #10 on: January 03, 2020, 05:03:06 pm »
I do have duel tanks.
Holidays have kept me busy so I have not had a chance to climb under and trace them but I am leaning toward that being it and for some odd reason having been rerouted by the PO into the rear intermediate harness loom. (any idea where they are supposed to run?)
The deeper in I get the more I think the wiring work was done by someone who almost, but not quite, knew what they were doing. lol  Local 2 bay shop with a crusty old Cooter type that knew how to make it work but was not very interested in actually doing it correctly, perhaps.
Offline 75gmck25
« Reply #11 on: January 04, 2020, 06:07:45 am »
Dual fuel tanks have a rubber plug and wires running through the firewall above the brake pedal area, but there should be at least 4 wires.  At least two of them should be tan or tan/white because that is the typical color of the sending unit wire.
Bruce
« Reply #12 on: January 04, 2020, 10:17:44 am »
Offline 82apache
« Reply #13 on: January 05, 2020, 12:16:00 am »
Thanks but these wires are not actually part of the RIH, nor the Rear harness, they are just routed through the same wire loom tubing as the RIH.
The PO had spliced into the the RIH to power some sort of a power receptacle in the interior bed wall and in the process cut off both the plug at the end of the RIH and the plug at the beginning of the rear harness. The RIH and the RH are currently spliced together instead of plugged together and that is what got me started on this. I am replacing both harnesses and found the extra wires in the loom tube.
Offline 82apache
« Reply #14 on: January 05, 2020, 12:31:23 am »
Bruce
OK, Looking from the grill,  these come trough the firewall through a rubber plug located to the left of the brake booster and through the right side of the engine indent. Only two wires and those fused together like speaker wire is.  It all looks factory and it does not appear that there was ever any other wires breaching the firewall through that plug.
The weather will be too wet to crawl under for the next few days, I will see if I can get a good pic tomorrow.
