Author Topic: No med. or low on blower motor..  (Read 29508 times)
Offline Sideways the Seven
  • That one guy. No, not that one, the other one. Yeah, him.
  • Work in Progress
Re: No med. or low on blower motor..
« Reply #15 on: March 05, 2020, 02:30:15 pm »
Fire the parts cannon
Ok, so there were plenty of relays in my bags of spare parts but nothing for the blower motor. So I DON'T have to fire the parts cannon, what else could it be if it's not the resistor?
Sent from my GM1915 using Tapatalk
1981 C10 LWB
1987 R10 Suburban
« Reply #16 on: March 05, 2020, 03:10:18 pm »
What are you working on? Does it have AC? What's your problem, high speed only?
  • Work in Progress
« Reply #17 on: March 05, 2020, 06:46:45 pm »
It's an '87 Burb with A/C. The fan only blows on high. I already swapped the resistor
1981 C10 LWB
1987 R10 Suburban
Offline philo_beddoe
  • 77 C-10
« Reply #18 on: March 05, 2020, 09:54:54 pm »
Same problem here, and i aint tried nothin,,and im all out of ideas!! Doh!!!
« Reply #19 on: March 06, 2020, 06:36:03 pm »
1)With AC
2)Without AC
  • Work in Progress
« Reply #20 on: March 06, 2020, 06:55:57 pm »
1)With AC
2)Without AC
Thanks!!
1981 C10 LWB
1987 R10 Suburban
  • 77 C-10
« Reply #21 on: April 14, 2020, 07:43:36 pm »
Oh, BTW, VZ was right. I finally stopped into an O'riellys and got a new resistor for the heater. Installed and now all three levels work, low-med-high.
  • 77 C-10
« Reply #22 on: May 26, 2020, 10:04:51 pm »
Not so fast, it still doesn’t work on med. But it does run on the low setting as soon as I turn the key...as it should. I could swear it worked on all three settings after replacing the resistor. Think it could be low-med-high switch? Won’t need until Oct. anyway.
« Last Edit: May 26, 2020, 10:08:42 pm by philo_beddoe »
« Reply #23 on: May 27, 2020, 05:53:07 am »
Put it on medium with the key on and go mess with the connection at the resistor. If it starts working then you have corroded connections.
  • 77 C-10
« Reply #24 on: June 21, 2020, 06:34:59 am »
Knowing me its probably clean, i despise corrosion. But will go try that anyway and let you know. Thanks
  • 77 C-10
« Reply #25 on: November 27, 2020, 07:53:25 am »
Update: yes it was corroded connections, disassembled, cleaned and re-attached. Lo-med-hi work great.
