Author Topic: No med. or low on blower motor..  (Read 29507 times)
Offline philo_beddoe
  • 77 C-10
« on: January 29, 2020, 10:12:50 pm »
It appears the heat (fan) setting only cranks on high. I cant hear it go from low to med. Why is this?
Don't think its the blower motor...hi, med, low fan switch?
« Last Edit: January 29, 2020, 10:16:44 pm by philo_beddoe »
Re: No med. or low on blower motor..
« Reply #1 on: January 30, 2020, 04:40:13 am »
Check the blower motor resistor.
Offline Sideways the Seven
  • That one guy. No, not that one, the other one. Yeah, him.
  • Work in Progress
« Reply #2 on: January 30, 2020, 08:29:29 am »
I just noticed I have this same issue, this morning. Where is the resistor located?
1981 C10 LWB
1987 R10 Suburban
« Reply #3 on: January 30, 2020, 10:28:18 am »
Non-AC is inside the cab behind the glove box door I think.  AC versions is outside on the AC box on top.  When I suspect something I have no clue my first step is to go to Autozone site, figure out what I need then find a picture to know what I am looking for, for my particular application.
Online Rapid Roy
  • Euless, Texas
« Reply #4 on: January 30, 2020, 11:24:18 am »
FYI  (pic)
I removed the top wire (yellow) from the connector on resistor so fan does not run on the low speed when key on. When I first start in the early mornings, when vacuum goes down, fan was always blowing from top vents and in winter I had cold air  blowing  in my face. Not sure what all models has this type. This was with the help of an electronics engineer co-worker. Now fan has an OFF position. It now seems more normal.
Mopar by Birth
Chevy by Choice
  • 77 C-10
« Reply #5 on: February 03, 2020, 10:15:53 pm »
Ok, i'll check that resistor, shouldnt be a problem. Been wrestling with a 1991 Husqvarna chain saw, nearly gave up the ghost, but i saved it. Rips and screams again.
  • Work in Progress
« Reply #6 on: February 19, 2020, 08:25:42 am »
Ah, thanks!
1981 C10 LWB
1987 R10 Suburban
  • Work in Progress
« Reply #7 on: February 20, 2020, 09:34:44 pm »
Welp, the resistor didn't work for me. Guess I'll check the relay
Sent from my GM1915 using Tapatalk
1981 C10 LWB
1987 R10 Suburban
« Reply #8 on: February 21, 2020, 04:14:25 pm »
Fire the parts cannon
  • Work in Progress
« Reply #9 on: February 21, 2020, 06:24:56 pm »
LMAO I'm not going quite that far. I think an extra one came with the truck along with an extra blower motor and whatnot.
1981 C10 LWB
1987 R10 Suburban
  • 77 C-10
« Reply #10 on: February 23, 2020, 10:05:01 pm »
Gotta love the parts cannon, end up with a buncha new stuff and it still doesn't work! lol...
Found one, $12, O'Reilly.
« Last Edit: February 23, 2020, 10:15:10 pm by philo_beddoe »
« Reply #11 on: February 24, 2020, 03:53:11 pm »
Is your truck AC or non AC? The resistor is dfifferent.
Offline JohnnyPopper
  • Old Goof
« Reply #12 on: February 25, 2020, 08:23:57 am »
The problem is obvious: you're on the wrong radio station!
1980 C-10 under construction
  • 77 C-10
« Reply #13 on: March 03, 2020, 05:59:32 pm »
No way man! I listen too conservative talk radio only.
  • 77 C-10
« Reply #14 on: March 03, 2020, 06:00:21 pm »
Non A/C, the pic is for non i believe.
