Author Topic: Coil spring air bags  (Read 4595 times)
Offline philo_beddoe
  • 77 C-10
« on: February 06, 2020, 08:36:17 am »
I have a 2006 Pathfinder and it rides like a boat on top of a tank. After all new shocks, the front end is pretty good, but the rear is still floaty and has that "bottom out" feel when going over a dip or rise in the road, if i have passengers its like sitting in the back of a school bus. Some research shows that coil spring air bags was the only solution. Anyone agree with this?Are they a waste or do they really work? This is for a simple application, no hauling at all.
I think the problem is just a poor factory design.
Re: Coil spring air bags
« Reply #1 on: February 06, 2020, 09:04:29 am »
That sounds like a reasonable solution to the issue you are having.
« Reply #2 on: February 06, 2020, 02:56:35 pm »
Have you thoroughly inspected the control arms, ball joints, differential mount, body mounts etc?
  • 77 C-10
« Reply #3 on: February 08, 2020, 01:42:39 pm »
Not really, but i will spend some time under there and make sure things are clean and tight. Stand by.....
