Author Topic: Finally on  (Read 27145 times)
Offline Shifty
  • I bleed Bowtie red...
Re: Finally on
« Reply #15 on: February 08, 2021, 08:46:21 am »
Is your truck stock height or did you lift it to fit that size of tires?
Stock height.
98 C2500 ext cab longbed
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Finally on
« Reply #16 on: March 22, 2021, 01:30:43 am »
How hard is it to pop the hubcaps off with that deep of a rim?  I've seen online that's the only complaint people have about them.  I know I could figure something out, but if you already know how that's way easier... :P
Offline Shifty
Re: Finally on
« Reply #17 on: March 22, 2021, 09:55:29 am »
I think the problems arise when you go with a 10" or wider wheel.  Mine are 8", and only slightly different than the OE's.
Offline mrghostwalker
Re: Finally on
« Reply #18 on: March 22, 2021, 01:22:58 pm »
Nice rubber!
Offline Shifty
Re: Finally on
« Reply #19 on: March 23, 2021, 09:36:40 am »
Thanks again!  They sure changed the character of the truck!
  • Z62 ON-ROAD
Re: Finally on
« Reply #20 on: April 27, 2021, 02:00:33 am »
How do they balance and ride at 70mph?  One reason I don't like my wheels is they have to be lug-centrically balanced which is extremely hard to find a place that will do that, like finding hens teeth.  I had my new tires road force hunter balanced but they still aren't as smooth as last time i had them lug centrically balanced.  since then the tire place i used to go to got rid of their adapters because corporate told them lug or hub centric can both be balanced the same through the center hole...  BS.  Other shocking thing was pro mechanics throwing away a tool (LC adapters) because of corporate.
  • Z62 ON-ROAD
Re: Finally on
« Reply #21 on: April 27, 2021, 02:04:42 am »
I'm liking your wheels and tire size because their within negligible of my tire size.  yours would be 25mm wider and 0.2" taller than mine are, says the miata tire calculator.  I know theres differences in brands n such but You're selling me more n more on them.  Just gotta find 2 more decent hubcaps and I'm 1.4 the way there...lol  Nice to know you have 8" rims.  they look great on there.
Offline JohnnyPopper
  • Old Goof
Re: Finally on
« Reply #22 on: April 27, 2021, 08:04:04 am »
I've got some hubcaps, but not the ones with the 4x4 hole. LMK if you want to see pics
1980 C-10 under construction
Offline Shifty
Re: Finally on
« Reply #23 on: April 27, 2021, 09:33:31 am »
Oh, I wish....that's a lofty speed to attain with 4:56 and a TH400.   60 is about all I can manage without the motor hating me.  At 60 though, all is well.
  • Old Goof
Re: Finally on
« Reply #24 on: April 27, 2021, 02:46:42 pm »
That's why I changed out my rear end to a 3.41 Zoom!
Offline Mike81K10
Re: Finally on
« Reply #25 on: April 27, 2021, 10:36:59 pm »
Fuel is looking a little low.
  • Old Goof
Re: Finally on
« Reply #26 on: April 28, 2021, 12:18:57 am »
Was hoping someone would notice... ;D
Glad for 2 tanks!
Offline Shifty
Re: Finally on
« Reply #27 on: April 28, 2021, 09:31:41 am »
I'd have to do 2 diffs... :P
  • Old Goof
Re: Finally on
« Reply #28 on: May 21, 2021, 09:46:45 pm »
If you're not into 4x so much it may be worth it.
All I know is my motor doesn't hate me anymore... 8)
Having said that, I'm not sure these trucks were designed to do high speeds, or if speed was even a consideration... :o
Re: Finally on
« Reply #29 on: May 22, 2021, 06:10:57 am »
That is why you should optimize your transmission and fit the appropriate final drive ratio to compliment it. Cruising on the highway should not involve over 50% throttle to keep up with the flow.
Quote
It's evident they missed the mark in gearing when you drive anything that still resembles stock. They made them look good on paper, that's about it, even with the 55MPH speed limit.
