Author Topic: 1976 c10 A/C question.....Another one!  (Read 6325 times)
Offline truxson
« on: February 15, 2020, 11:08:00 am »
Folks I need some more help....
First, thanks to all those that have helped me in the past.  This is the only forum where I can get correct, actionable information!
So...I had a problem with the floor rusting out in my truck.  After removing carpet, repairing the sheet metal, coating and whatever, I thought I had the problem 'cured'.  I expected external moisture was the problem.  But it isn't...
The A/C condensation is running down on the inside, instead of the outside.  I couldn't tell this when the carpet was installed and in fact I didn't even notice it.
Can anyone give me some advice on re-directing the condensation from the evaporator core outside, instead of running in on the floor?
Thanks, david. (truxson)
Re: 1976 c10 A/C question.....Another one!
« Reply #1 on: February 15, 2020, 12:44:14 pm »
The drain is probably clogged. Look at the evaporator case in the engine compartment directly below the evaporator. There is a drain hole, blow it out with compressed air, otherwise, take everything apart and clean it.
Offline truxson
« Reply #2 on: February 15, 2020, 01:34:00 pm »
Thanks.  I'll check that out.
Regards, david.
