Members Rides
80 C10 SWB "The Ruby Build"
7
Topic: 80 C10 SWB "The Ruby Build" (Read 220386 times)
Thompson335
February 26, 2020, 10:56:51 am »
Hi everyone
Wanted to start a build thread. I have had the truck about a year. The goal is a fun everyday driver.
To that end the plan is
LS swap, and turbo with around 600HP
4L80E trans
Suspension improvements
AC, Sound proofing, and better seat.
This is what I started with
Thompson335
Re: 80 C10 SWB "The Ruby Build"
February 26, 2020, 11:04:40 am »
Custom Delux with 6 cylinder and 3 on the tree.
in desperate need of a new stance I added Western Chassis 4/6 drop kit
marcoman
February 26, 2020, 11:58:45 am »
Cool truck, I'm planning an LS engine in the future as well. I've got an '84 GMC 1500 and look forward to your future posts. Good luck!
Thompson335
February 26, 2020, 01:07:37 pm »
Did some cosmetic work to the front.
Chrome bumper
painted the grill and headlights black.
Thompson335
February 26, 2020, 01:18:00 pm »
It was not very long before the old 6 cylinder gave up. It was on its last leg when I got it.
started prepping for the LS swap!
Thompson335
February 26, 2020, 01:19:35 pm »
every thing all removed and painted up.
Thompson335
February 26, 2020, 01:25:27 pm »
had a small leak in the cowl I needed to address, and I wanted to add vintage air.
welded up the seam where it was leaking, added new seam sealer and covered everything inside the cowl with flex seal. Man working and cleaning the cowl area is a pain!
February 26, 2020, 04:52:16 pm »
reducer and an acid brush works great for smoothing out seam sealer.
Thompson335
February 27, 2020, 07:46:30 am »
added hydro boost to it while I had the front clip off
Thompson335
February 27, 2020, 07:54:00 am »
here is my 5.3 straight out of the pick in pull.
Gave it a good pressure was and a set of shorty headers from Speed engineering I believe.
next up is a Isky Triple 12 cam, some springs, and some paint.
Shifty
I bleed Bowtie red...
February 27, 2020, 08:39:15 am »
Keep them pics coming!
98 C2500 ext cab longbed
Thompson335
February 27, 2020, 10:40:52 am »
added a 4L80E from the pick and pull. unfortunately it had a crack in the hsg I had to weld up, but it all worked out well.
Reworked the original harness per LT1 swap info.
Installed some Tejas Steelworks engine mounts and trans mount. It set the engine in a very nice location for a daily driver and gave me great room for factory AC compressor.
Only issue I had was the headers hitting the big ears on the 4L80E. Had to cut them off to make room.
Thompson335
February 27, 2020, 10:46:42 am »
here are a couple installed pics before the front clip went back on.
Thompson335
February 27, 2020, 01:20:48 pm »
painted up the front clip and reinstalled, added big block radiator, made a shroud and installed a couple fans I picked up from the junk yard.
Thompson335
March 10, 2020, 10:26:17 am »
Here she is front clip installed with 5.3 all wired up and running.
7
Members Rides
