Author Topic: OEM exhaust manifold AIR thread size?  (Read 10798 times)
« on: April 22, 2020, 03:15:08 pm »
Has anyone removed leaky AIR system and plugged the manifolds?  The thread size isn't standard pipe.  Does anyone know of a source for plugs to delete these?  The application is a 1986 Chevrolet C20 7.4L  Thanks in advance
Re: OEM exhaust manifold AIR thread size?
« Reply #1 on: April 23, 2020, 08:17:44 pm »
Should be 1/2"-20 but check first to be sure.
« Reply #2 on: April 23, 2020, 09:24:25 pm »
I measured the thread pitch and got 18.  I will have to mic it.  Thanks
« Reply #3 on: April 24, 2020, 05:20:15 am »
Let us know what you find. I have a set here I could dig out to check if it stops raining.
Offline 75gmck25
« Reply #4 on: April 24, 2020, 02:49:38 pm »
Its been a long time since I plugged the AIR inputs on my Ford.
IIRC, I took off the AIR "manifold", cut each small pipe just above the screw-in fitting, and slipped the fitting off the pipe.  Then I found ball bearings that were the right size and dropped them into each hole in the exhaust manifold.  Then I screwed each fitting back on so the ball bearing sealed off the hole in the fitting.   It was in the days before I discovered JB weld, but I think that would have helped with the sealing process.  YMMV.
Bruce
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: April 24, 2020, 03:02:57 pm »
Very clever Bruce!
I did a valve job on a GM V6 only to have one of the center head bolts strip out in the block.  :o
I found a longer head bolt that would reach into the block about 3/4", so I got the idea to find a nut and get it onto the bottom of the bolt.
Problem was obvious, but I found a way to get the nut down into the block.
I brazed a steel rod to the nut at just the right angle, and dropped it into the galley and BOOM! She grabbed, I torqued, and snipped off the steel rod.
Man was I glad to move that project down the road!
1980 C-10 under construction
