Author Topic: Axle Seal? Yeah pretty sure but would like another opinion :)  (Read 5757 times)
Offline mpeche92372
Hi Guys,
I have been a member here for a long time, but I don't post much..  just kinda real a lot, etc.  I had my 87 K10 1/2 ton in storage for a few months, since I was moving.  I finally brought it out of hibernation, drove it to my new home and I believe I have a bad axle seal, as the pictures are what greeted me this AM.  Just looking to have some of you guys here that know a TON more then I confirm it.  I also have to come up with the parts list to get this done:
Axle Seals (might as well do both sides)
Gear Oil
Gasket for diff cover
RTV sealant for cover
Any special tools I might need?
Tips tricks??
Thanks in Advance!!!
Re: Axle Seal? Yeah pretty sure but would like another opinion :)
« Reply #1 on: May 04, 2020, 01:54:44 pm »
If it is gear oil, then yes it would be axle seals. If it is brake fluid, then wheel cylinder.
Offline mpeche92372
« Reply #2 on: May 04, 2020, 02:37:24 pm »
Thanks Vile...
I never thought about it possibly being a wheel cylinder.  Does the fluid have a different smell/viscosity?
I guess I will start by pulling the wheel off and go from there.
« Reply #3 on: May 04, 2020, 03:19:18 pm »
yes and brake fluid will rinse away with water while gear oil will leave a stinky and slippery residue.
Offline mpeche92372
« Reply #4 on: May 04, 2020, 03:42:48 pm »
Another great tip.  I knew you were the expert   ;D
I'm pretty sure at this point it's an axle seal.
If I pull the wheel and drum off will I be able to tell for sure??
Offline FlatBlack77
« Reply #5 on: May 04, 2020, 05:46:48 pm »
Once you get the drum off the source will be obvious.
Axle seals arent fun to change but it's not as hard as changing the axle bearings. I went through that last summer.
