Author Topic: Drop Shackles  (Read 5890 times)
Offline macr0w
Drop Shackles
« on: May 19, 2020, 08:27:08 am »
Hey guys, a couple of quick questions about about drop shackles.
If I install a set of 2" drop shackles on my 84 do I need to worry about the pinion/driveline angle?
I understand that 2" drop shackles will give me about 1.5"-2" drop which is all I really want. (for now  ;D)
With that said, will I need shorter shocks?
Thanks in advance.  8)
Re: Drop Shackles
« Reply #1 on: May 21, 2020, 10:48:42 am »
You can install shock extenders but if you need shocks just replace them with the proper length shocks. You should always verify your pinion angle and driveshaft angle.
