Author Topic: 2wd to 4x4  (Read 6995 times)
Offline 77GMCSerria
2wd to 4x4
« on: November 09, 2006, 10:32:00 am »
I would like to convert a 1989 GMC Crew Cab 2wd Auto 350 to 4x4. What would I need to do or buy to do this swap? I plan on getting a 4x4 parts truck for the 4x4 parts. How long would this take to convert? What kind of mods do I have to do to the frame, any cutting, welding?
Thanks
Offline roundedline
Re: 2wd to 4x4
« Reply #1 on: November 09, 2006, 03:10:00 pm »
If you have a working donor, you just need to swap all the parts over.  The brake lines and possible shock mounts my mount differently, but the framerails are the same.  You also need the rear spring mounts from the 4x4.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 77GMCSerria
Re: 2wd to 4x4
« Reply #2 on: November 09, 2006, 07:17:00 pm »
Okay would I have to do any welding or would all of the 4x4 components just bolt up to the frame?Any pictures or links for this type of conversion?
Edited by: 77GMCSerria at: 11/9/06 10:16 pm
Offline DnStClr
Re: 2wd to 4x4
« Reply #3 on: November 10, 2006, 11:10:00 am »
Don
87 Chevy Silverado
Offline 77GMCSerria
Re: 2wd to 4x4
« Reply #4 on: November 10, 2006, 01:13:00 pm »
Okay converting the frame seems like alot of work. So I was woundering if a regular cab or crew cab would fit on a 4x4 Suburban frame or is that also alot of work?
Offline roundedline
Re: 2wd to 4x4
« Reply #5 on: November 10, 2006, 11:36:00 pm »
the regular cab will probalby bolt to most of the Burb frame, but the Crew would have to have mounts fabricated.  In additon, a long bed won't fit on a burb frame with the regular cab, the wheelbase is too short.
Project Su
Jimmy 2WD Project
Offline 77GMCSerria
Re: 2wd to 4x4
« Reply #6 on: November 11, 2006, 10:25:00 am »
Thats fine if long bed wont fit, the bed size dosen't matter, even if I have to fab one up to fit.
