Author Topic: Clutch Slave Cylinder Repeated Failure  (Read 4472 times)
Offline claude
« on: July 20, 2020, 12:12:05 pm »
1985 K20 that I rebuilt 355 engine about 3 years ago & put on 1&5/8 Hooker headers. I am on my 3rd clutch slave cylinder. I am sure that the cause of problem is the driver side header that is too close to the line from the master cylinder(about one inch) and to the slave cylinder(1.5”). When I installed the new slave cylinder the Dot 3 fluid was almost black. I purchased some Titanium heat wrap and completely wrapped slave cylinder housing. Tried to wrap lower part of headers that is close to slave cylinder and fluid tubing but found it impossible to do with headers installed. What have fellow members done to solve this problem?
1985 K20, manual T, 373 gears, 208 transfer case
Rebuilt roller 355 engine, Comp XE264XR cam 212/218 @ .050, .487/.495 lift w/1.5 RR, LSA 110, Dart Iron Eagle Heads with 2.02/1.6 SS valves. 325 HP at 4000 RPM. 335 HP @ 4900.
421 ft*lbs torque at 4000RPM
Offline Shifty
  • I bleed Bowtie red...
Re: Clutch Slave Cylinder Repeated Failure
« Reply #1 on: July 20, 2020, 12:24:22 pm »
Anyway to fab-up a sheet of aluminum to shield the slave cylinder?
98 C2500 ext cab longbed
« Reply #2 on: July 20, 2020, 01:01:00 pm »
Offline MIKE S
  • Member
« Reply #3 on: July 20, 2020, 03:10:04 pm »
When these trucks were new at best I could only get them to last 1-2 years under daily driving farm trucks. I tried aftermarket cast iron and they were no better.
Offline claude
« Reply #4 on: July 21, 2020, 09:41:23 am »
Reroute with a braided hose
https://www.summitracing.com/parts/afc-40280
Thanks Shifty & VileZambonie. I’m going to both suggestions.
