Author Topic: Intake swap question for 350  (Read 11776 times)
Offline Dirty Ron
« on: July 29, 2020, 11:51:23 am »
I seen from this website, sorry if this isn't allowed, https://www.fourwheeler.com/how-to/engine/1801-junkyard-fuel-injection-conversion/ , but figure it'll be faster. Can a 1994 Chevy 1500 with a 350 intake fit on a late 70's to early 80's 350? I wanting to know cause I got a 94 Chevy I can't use but be willing to pull off the gas tank and fuel lines, wire harness, ECM, intake, distributor to fit to the 1977 Big 10 I got. The gas tank is on driver side on 94 chevy and the fuel tank is on the passenger side on 77 big 10.
Re: Intake swap question for 350
« Reply #1 on: July 29, 2020, 11:57:24 am »
Not without modifying it. You could easily bolt a TBI adapter onto your intake manifold though ;)
Offline Dirty Ron
« Reply #2 on: August 04, 2020, 11:42:50 am »
Will the 94 350 distributor work on the 77 350?
« Reply #3 on: August 04, 2020, 03:04:58 pm »
Yes
Offline Dirty Ron
« Reply #4 on: August 05, 2020, 11:51:30 pm »
How about the heads? Will they swap with or without modding?
« Reply #5 on: August 08, 2020, 05:39:57 pm »
Not without matching them to the intake.
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: August 08, 2020, 07:09:54 pm »
Good to have spare trucks lying around.
You can take the whole topend, heads, intake, distributor and TBI with computer if you want, off the '94 and put it on the '77. You can also use the serpentine system as an upgrade. Beats a bunch of v-belts.
