Author Topic: Where is the factory installation for the spare tire??  (Read 8686 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: July 29, 2020, 06:15:35 pm »
I have a 1974 chevy C10 stepside.  After the 3rd flat in the last year I finally had the guy at America's tire order me a new stock rim and another one of the tires I have on the truck, which are a standard size according to the manual.  (15 x 7 if memory serves).  So now I have to get the tire on the truck.  Someone along the line installed a chain hoist mechanism in the back and cut a hole so that a crank could get to it and hoist up the tire up under the bed, but there is no mount stuff.  Also the exhaust pipes are just wider than the tire.  (less than one inch on either side).  I am thinking a shield of some kind is in order to keep the smell of burning rubber from entering the cab when the tire catches fire...  A picture of the factory stuff would sure be helpful.  Maybe I have the exhaust re-routed further apart and get some angle welded in there?  Anybody got any idea where the tire used to go??  thanks in advance for your assistance.
Ricky
Re: Where is the factory installation for the spare tire??
« Reply #1 on: July 29, 2020, 06:36:42 pm »
The glide out carrier under the bed behind the axle, in front of the grille, inside the bed, can of fix a flat, AAA, lots of options.
Offline fiddler
« Reply #2 on: July 29, 2020, 09:41:28 pm »
so are there parts for the glide out carrier behind the axle?  It will cover my polished aluminum cast differential cover but I only put that on as I heard the pressed sheet metal ones always leak and mine was leaking.  In other words I don't mind covering it up...
Ricky
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: July 29, 2020, 09:50:04 pm »
The glide out was factory but a lot of people take them off or let them rot away. I'm sure yours is gone if they put a cable hoist system in. On one end there was an extremely long carriage bolt and the other had a a special wedged lever mechanism. I gave mine to a member on this forum. Don't remember who it was...phil something. I run 35,s so spare stays in the bed. If you really want one I can check the parts field and see if I have one still hanging around but driving or you paying for shipping is up to you.
« Reply #4 on: July 30, 2020, 07:45:58 am »
The spare tire hoists are available aftermarket and as long as you maintain them, they are much simpler and convenient to use. As far as covering up your rear end, no one wants to see your butt crack anyway.  :D Seriously though, you don't need a full size spare either. Go donut shopping from an astrovan or something.
« Reply #5 on: August 01, 2020, 10:59:24 pm »
This is the usual place
Offline fiddler
« Reply #6 on: August 03, 2020, 04:40:28 pm »
Thanks much!  That photo is quite helpful.  The chain hoist that is welded in place won't turn with the flimsy crank someone built for it.  I will maybe replace that as I have nothing else to work with.  I don't weld but I can take it to the guy who welded the steering box reinforcement for me....
Ricky
