Author Topic: Fuel tank delete  (Read 4584 times)
Offline 86square
Fuel tank delete
« on: August 05, 2020, 10:18:55 pm »
I’m looking for some help on deleting or by passing my passenger fuel tank with a 6port selector valve any help appreciated thanks!
Re: Fuel tank delete
« Reply #1 on: August 08, 2020, 05:12:06 pm »
It's pretty straight forwad. You simply bypass the valve altogether.
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: August 08, 2020, 07:23:08 pm »
Quick and easy way is get 3 barbed fittings the same size as the hoses.
1-Fuel supply
2-Return
3-vent
Disconnect the drivers side lines from the selector valve-switch combo. And using the Barbes, reconnect the lines to the hoses leading off the selector valve towards the engine. They are all different sizes so it's hard to mix them up.
To make this permanent and delete the whole passenger side tank, selector valve and tank selector switch, will be a little more involved. It's not hard, you will just have to pull the switch from the dash and connect the fuel pump power and sending units permanently to the driver's side tank. Now you have a switch hole for something else, lights, locker, fans,train horn, disco ball.....
