Author Topic: Possible reasons for burning SO much gas.  (Read 16417 times)
Offline 1980cdeluxe
« on: October 20, 2006, 11:30:00 pm »
Well I recently got my 80cdeluxe 4x4 back on the road, and man o man how I forgot how unreal the gas milage on this truck is. It had a full tune up before I parked it, and it doesn't leak gas obviously, but what could be some other reasons making this truck get 5mpg (ROUGHLY). It's basically pouring out at that speed, and it's only got a smallblock 350 from a 80 series ton van in it. 3.08 gearing, th400 transmission... I believe the timing is on, idle is 600-800rpm, and the carburetor is a 4brl holly 650cfm electric choke.. Doesn't matter if i'm on it all the time, or babing it... Gas milage doesn't change whatsoever. The stock quadrajet was just as bad. The motor has around 40k from when I got it.
Edited by: 1980cdeluxe at: 10/20/06 10:57 pm
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Possible reasons for burning SO much gas.
« Reply #1 on: October 21, 2006, 12:34:00 am »
vacuum leak would be first guess.  Do the ole wd40 trick to see if rpms go up.   then adjust carb.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
« Reply #2 on: October 21, 2006, 05:45:00 pm »
If everything is tuned properly as far as the ignition system is concerned then I would suggest recalibrating the carburetor.
Offline 1980cdeluxe
« Reply #3 on: October 23, 2006, 01:12:00 am »
What do you mean by recalibrating the carburetor, sorry for the vague question.
Multiple things i've noticed: Engine runs HORRIBLE when cold,  miss, black smoke, will backfire if I hit the gas more then a little etc. The engine runs great when at operating temperature at idle and AFTER about 1k rpm (smoking stops completely once it's warm). It has a slight hesitation when I inch on the throttle. I've also noticed if I punch it going down the road or at idle it has a dead spot in the carburetor before it "kicks" in and takes off. If I ease down onto so far then open it up it's fine. I also often smell gas once I park and get out of the truck, but I haven't found any leaks.
I suspect a carburetor problem, but yeah...
Edited by: 1980cdeluxe at: 10/23/06 12:13 am
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #4 on: October 23, 2006, 11:01:00 am »
sounds like a timing issue or carb is way off.  Perhaps choke is off.
double check timing.
SgtDel
aka "Andy"
www.delbridge.net
Offline Redneckchevy
    • Photo Bucket
Sounds like
« Reply #5 on: October 23, 2006, 09:32:00 pm »
Your choke is sticking..
Offline DnStClr
Re: Sounds like
« Reply #6 on: October 27, 2006, 11:08:00 am »
And one other thing is the tranny. I have a TH400 too- and am considering getting an overdrive (700R4)  to get better gas mileage.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline 1980cdeluxe
Re: Sounds like
« Reply #7 on: October 28, 2006, 01:45:00 pm »
I believe it has high gears, low rpms at 65mph so... My brother in-law agreed to let me try his quadrajet (originally came off my motor, I let him use it when I got the holly). He told me he recalibrated it to burn less gas. Going to see if It actually helps any, thanks for the tips so far.
Offline presleyhome
bad mpg
« Reply #8 on: November 26, 2006, 08:43:00 am »
Curious if you had anything new with this.  I have an 81 GMC C25 with a 350M, Quadrajet and 400 trans.  Mileage just stinks from idle to 40 Mph.  You can smell the rich gas.   On the freeway it gets 15mpg at 65+.  Timing is on, carb is brand new and all hoses are new. Did the same thing with the original carb, so I guessing it was not the issue.   I gather there is now easy way to test each of those sensor switches that the vacuum hoses connect to.  Must be 4 or five of them.  Maybe the HEI unit?   Motor runs great, but man....4 or five trips to the local grocery and I'm through a tank of gas!
Jim P
Re: bad mpg
« Reply #9 on: November 26, 2006, 12:51:00 pm »
If you are getting poor fuel economy again the 1st thing to do is make sure all of your ignition components are healthy (Cap & rotor, ignition wires, spark plugs -make sure they are correctly gapped etc) Check your base timing and your timing advance. If your trucks runs poorly after that and gets bad fuel mileage check your fuel metering. Carburetors are very basic. It's sort of like drinking soda through a straw. Odds are if you haven't toyed with the carb it's probably set up optimally for your engine however could be leaking internally. Q-Jets are notorious for internal leakage. If you rebuild the carb make sure you use some jb weld or epoxy to seal up the plugs at the bottom of the venturis. Other than that if you are still using that much fuel check your tank and lines and check your oil level to make sure it isn't leaking into the crankcase.
Offline xtreme80
Re: bad mpg
« Reply #10 on: December 04, 2006, 12:00:00 pm »
I know this is an older post, but I thought I would give somewhat of an update to your problem since mine just did the same thing.
I had a 350 with a factory QJ carb on it.  I was getting 10.2 mpg after I did the mileage test.  Had all the same problems as you when cold, and at low RPMs.  Yesterday it started getting worse and worse.  Took the intake off the top of the carb and looked into the butterfly valve with a flashlight.  I could see gas pouring into the carb where it shouldn't be.  The culprit: a leaky carb causing the engine to run like crap at low RPMs.
My guess for you would be to buy a 20 dollar carb rebuild kit, and a new float, and rebuild the carb.  It's only about a 2 hour project, and a Haynes manual will help out alot.
Offline ssgoodman
« Reply #11 on: December 30, 2007, 06:23:59 pm »
sorry for bumping an old post but i am having some of the same problems.  i am definately not an engine person, i know the basics and can do lot of the work if i can read a manual or if someone tells me what to do its just i cant really figure alot of it out on my own.  i know the truck does need new spark plugs and probably new wires since i believe its all original under the hood.
my question is when do you know its time to rebuild a carb?  and how tough would it be to rebuild a carter quadrajet if i have never done it before?  i want to wait until this spring to keep my truck on the road for the winter but if it didnt take long i would consider doing it here soon.
Sutton
« Reply #12 on: December 30, 2007, 07:05:19 pm »
Carburetors get dirty, gaskets crack, floats get burned, linkages get sticky, choke coils wear out, deposits build up, shafts wear out etc. If you identify a specific problem with your carburetor that would require taking it apart then it's time for an overhaul. If you're just doing a tune up get some carb clean and just clean it and change the filter.
Offline werewolfx13
« Reply #13 on: December 30, 2007, 08:42:52 pm »
Vile covered the reasons to rebuild the carb thoroughly..I won't rebuild a qjet, I replace it with somthing I'm comfortable tearing into, so how hard it would be for you, I don't know. Replace the plugs and wires and check the timing..then *SLOWLY* pour some seafoam through the carb with the engine running if you want, or get some of that spray cleaner.
The OP's problem sounded like a blown powervalve or accelerator pump diaphram to me..my '84 with a holley had the EXACT same symptoms, and it turned out to be three things: the accelerator pump diaphram was almost entirely gone, powervalve was bad, and the secondaries were screwed all the way shut.
Chris
'83 Chevy c10 Silverado SWB
Offline Bowtie Bomber
  • Rolling American Iron
« Reply #14 on: December 31, 2007, 05:50:03 pm »
My Holley did things like that also. Rebuilding it or if you are VERY lazy, leave the carb on the intake and just take the front bowl off the carb and rebuild it from there if you are having idle problems, since the front bowl controls the primary's and supplies the most amount of fuel the engine consumes. I personally take the whole thing off, but if it's a power valve then that works just fine.
Also gunked up needle and seats can make your carb act funny. Be sure to check those before anything in my opinion.
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
