Author Topic: Fuel Sender Question  (Read 6806 times)
Offline Tilleyman
  • Dunbordin
« on: October 12, 2020, 03:49:59 pm »
I have a '81 C10 shortbed with a H code 305. I need to replace my fuel sender but can't find anywhere whether it's a 2 outlet or 3.  I'd like to buy the new sender before I drop the tank and render my truck undriveable until a new sender arrives. Any input would be greatly appreciated.
Re: Fuel Sender Question
« Reply #1 on: October 12, 2020, 04:18:16 pm »
All you have to do is look. You can see it behind the cab.
Offline Bronze Knight
  • Wage Slave with a Dream
« Reply #2 on: October 12, 2020, 07:15:12 pm »
You can get the three outlet one and just cap it off with hose with a bolt in it or a rubber Vacuum end cap.
There is the send/pickup tube a return line and a vapor/emissions line. Depending on where you buy it the two outlet sender may be more expensive! The vapor/emissions tube is very short ends just inside the tank.
1985 Crew Cab, 454, TH350, NP205
https://imgur.com/gallery/RgCm5QK
Offline Mike81K10
« Reply #3 on: October 12, 2020, 07:26:08 pm »
I have an 81 K10 with duel 16 gal tanks and have 3 hose connections on the fuel sending units. Supply, return, and vent!
« Last Edit: October 16, 2020, 10:37:52 am by Mike81K10 »
Offline Tilleyman
  • Dunbordin
« Reply #4 on: October 15, 2020, 03:39:52 pm »
Thanks. It sounds like if I go with the 3 outlet I'm safe, because as you say, I can plug it if I have to. If I get a 2 outlet and need a 3 then I'm sunk.
« Reply #5 on: October 15, 2020, 04:13:43 pm »
WOW!  How many fuel lines connect to the fuel pump?
Offline Mike81K10
« Reply #6 on: October 16, 2020, 10:23:44 am »
Three hose connections on the tanks fuel sending unit (I should not have said three outlets - corrected), there is only one fuel supply (outlet), a return, and a vent (outlet) needed. I would imagine you have two hose connections on the fuel pump (a supply and a return coming from the selector valve) and a threaded connection where a line connects that goes to the carburetor if it is like my 81 K10. I attached a pic of my fuel tank selector valve, a little dirty (the pic is prior to my rebuild and is OEM). Wish the same Selector valve could still be found, new selector valves are shorter in length and have a little different design.
« Last Edit: October 16, 2020, 10:47:30 am by Mike81K10 »
