Author Topic: 76 with Ground Force lowering springs  (Read 7948 times)
Offline rsavant
« on: January 06, 2021, 06:32:34 pm »
Can someone explain what I need to do to give me the most clearance here? Bought the truck lowered like this. Looks great but I need the best ride I can get at this stance. Thanks!
« Last Edit: January 06, 2021, 06:40:57 pm by rsavant »
Offline rsavant
Re: 76 with Ground Force lowering springs
« Reply #1 on: January 06, 2021, 08:14:10 pm »
Anybody? 1st of all, GF's shortest springs give a 3-inch drop at most. Spindles appear stock. This appears to be more than a 3-inch drop in the front. Anyway, is the only remedy to get aftermarket lower control arms or cutting off the bump stops on these?
« Last Edit: January 07, 2021, 01:10:15 pm by rsavant »
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: January 12, 2021, 05:35:34 pm »
They make lower profile bump stops, look at Energy.
Sorry no-one got back to you, pry think we're rude... ::)
Beautiful truck BTW!!
What did you have to give up for her, if I may ask?
1980 C-10 under construction
« Reply #3 on: January 12, 2021, 05:46:37 pm »
Lowering spindles is a much better solution than springs.
Offline rsavant
« Reply #4 on: January 12, 2021, 06:37:13 pm »
Thanks for the replies guys. And thanks for the compliment JP. After a little looking around at other drops I see that the guy who restored her, kinda took the cheap route. He didn't even have the camber adjusted correctly. Eventually I'll get drop spindles. I want it to one day handle and ride the best possible. But for now I'm going to remove the bump stops and check out the short ones you mentioned. I paid $8k for her. Maybe a lil too much, but she does have lots of good stuff done as well. Hopefully when I get everything right I'll recoup on my investment.
Sent from my GM1917 using Tapatalk
  • Old Goof
« Reply #5 on: January 12, 2021, 08:38:28 pm »
At first glance, that sound reasonable. I paid 9 for my K10, barn find, just dirty.
Yeah, get your wheels aligned before you buff of your tread.
