Author Topic: trans mount  (Read 4494 times)
Offline barneyb1
trans mount
« on: December 24, 2006, 04:04:00 pm »
im just getting my feet wet with this truck
i was putting exhaust on the other day and i can wiggle the transmission over the crossmember
how tight should it be
i have a 79 gmc
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: trans mount
« Reply #1 on: December 24, 2006, 08:10:00 pm »
It shouldn't wiggle at all.  It won't be solid as metal either, remember, it is on rubber pads bolted to the crossmember. With great force, i would guess you could shift it over a half inch but it comes right back into position.
You may need to replace your tranny mount.  I had to one time.  I couldn't figure out why when I go fast around a right turn a thud, thud, thud,...(fast repitition) sound loudly appeared. It would only do that with fast right turns.
I finally looked under the truck to find out that the front yoke/ujoints were hitting the heat shield of the catalytic converter--which was to the left of the yoke.  When the centrifugal force of the vehicle shifted the tranny/driveshaft towards the heat shield, it would rub it until I straightened the truck up again.   Culprit?  Tranny mounts.  The tranny was just sitting on top of the crossmember basically. The rubber had worn around the two little bolts that hold the rubber on the mount.  The mounts are cheap and any good auto parts place will have them.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 12/24/06 8:21 pm
Offline barneyb1
Re: trans mount
« Reply #2 on: December 25, 2006, 03:46:00 pm »
how tough of a job is it to replace the mount
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: trans mount
« Reply #3 on: December 26, 2006, 01:02:00 am »
Not tough.  I may be wrong, it has been a while, but I think you just unbolt the existing mount from the crossmember, take a jack and raise the tail of the tranny a little to remove and replace the mounts (dont raise too much, fan of engine could go into the radiator). I dont think i had to remove the crossmember while supporting the trans.
SgtDel
aka "Andy"
www.delbridge.net
Edited by: SgtDel  at: 12/26/06 8:44 am
