Author Topic: Switching to Crank  (Read 24632 times)
Offline 87 ChevyVan
Switching to Crank
« on: January 23, 2021, 09:06:00 am »
I'm looking for instructions on how to switch to a hand crank.  My 87 Chevy Van has electric window and door locks.  The passenger side window does not work proper, I'm thinking the easiest fix for me is to replace it with a hand crank.
I'm looking for instructions, and what parts I might need.
Thanks to the community.
Offline Mike81K10
Re: Switching to Crank
« Reply #1 on: January 23, 2021, 07:56:24 pm »
What is wrong with your window now? If it is the regulator, I would replace it with the OEM. However, there is not much difference in the installation mounting configuration of a manual regulator.
Offline 87 ChevyVan
« Reply #2 on: January 23, 2021, 08:49:41 pm »
It sticks on the way up, motor whines, but does not have the push.  It totally locked up the first time after I bought the truck, had to research on the internet tricks to get it up on a road trip.  We got it up, but don't like to use it much now.
What is a OEM?
I have not gotten inside to look at it, I'm a bit timid to do so.
I probably should look up a youtube video on the topic.
« Reply #3 on: January 24, 2021, 01:46:27 pm »
Try lubing up the felt and window run channels with some lubricant. Pop the door panel off and lube up the tracks and see what it does. Going to manual cranks sucks.
Offline 87 ChevyVan
« Reply #4 on: January 25, 2021, 08:46:27 pm »
Probably best to start with this.
Is the door panel easy to pop off?
I'll check youtube.
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: January 25, 2021, 09:44:34 pm »
Relatively easy, watch the wiring, don't want to make it worse.
Having said that, another problem IS the switch. Use some electric solvent while you have it open.
DeoxIT Contact cleaner, the D5 type is best. Flushing action, safe on Plastics. Use it on the wire lugs too.
1980 C-10 under construction
