Author Topic: Turn signals  (Read 3707 times)
Offline TheBigHat
Turn signals
« on: February 04, 2021, 05:29:44 pm »
Recently my turn signals have stopped working. My hazards work but they just blink quickly. Not sure they are supposed to do that. When I use the lever there is no light on the dash either. I tried the flasher fuse. That didn't work. Where do I beigin on this issue?
Re: Turn signals
« Reply #1 on: February 04, 2021, 07:12:59 pm »
Year, make, model?
Does it have two flashers?  It should.  Try switching them.
Offline TheBigHat
Re: Turn signals
« Reply #2 on: February 05, 2021, 06:10:26 am »
78 K20, I only saw one under there. I'll look again.
Re: Turn signals
« Reply #3 on: February 05, 2021, 10:02:07 am »
If there is only one, replace the one that is missing.  You probably should replace the hazard flasher, regardless.  If the corner lamps are LED, use flashers designed for LEDs.
