Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
A/C only works on hi BUT heat,Vent, Def positions have all speeds?
Topic: A/C only works on hi BUT heat,Vent, Def positions have all speeds? (Read 10611 times)
MikecLA
February 05, 2021, 01:26:55 pm »
So i got my 74 C10 factory a?c all up and running cold finally. in A/C position blower motor fan only works in HI position. But when on Vent , Heat Def all speeds work.
Factory Wiring diagram isn't clear at the switch whats going on but think its up here, anyone else run into this? Resistor should be fine due to all other functions have speed control. thanks
Rapid Roy
Euless, Texas
Re: A/C only works on hi BUT heat,Vent, Def positions have all speeds?
February 05, 2021, 01:32:44 pm »
Slide the temperature arm from all the way cold about 1/4" toward hot. You should feel a slight indent. Then all speeds will work.
With the arm all the way cold is the same as "Max AC".
Last Edit: February 05, 2021, 01:34:22 pm by Rapid Roy
Mopar by Birth
Chevy by Choice
MikecLA
February 05, 2021, 02:24:55 pm »
Wow Roy that's some Jedi mind stuff right there!
Thank you, I love that function!, cant believe i didn't notice it yet.
Rapid Roy
Euless, Texas
February 05, 2021, 04:51:11 pm »
You are welcome. I did not know about it till I had the truck 4 years. I happen to find out from someone else.
Enjoy
Mopar by Birth
Chevy by Choice
Rapid Roy
Euless, Texas
February 05, 2021, 05:10:38 pm »
Also, with all the climate control settings to off, the fan still blows on low. It defaults through the ac vents. The switch speeds are Lo, Med 1, Med 2, Hi. I found out a way to eliminate the Lo speed fan from blowing. It was especially bad during winter when it would blow cold air in my face when starting. The upper wire in the resistor connector can be removed and Lo speed is eliminated.
Mopar by Birth
Chevy by Choice
MIKE S
Member
February 05, 2021, 09:32:34 pm »
If you like the way the fan works that is fine. It used to irritate me that you could only have recirculate with high speed. There is a single wire on the control head you can remove that will allow you to have any speed while on recirculate.
Last Edit: February 05, 2021, 09:39:21 pm by MIKE S
February 06, 2021, 06:38:06 am »
It should default to defrost and floor in the off position and run the fan anytime the key is on. This is actually a good thing, especially in the old heater box design. It keeps the mice strong trying to run the wheel
MikecLA
February 06, 2021, 04:18:44 pm »
The always on low speed can be annoying,blowing hot or cold air depending on the season. i might wire in a switch perhaps. thanks again.
bd
February 06, 2021, 07:21:00 pm »
"Annoying" is driving a vehicle that has mildew permeating the cab. Drying the ductwork to prevent mildew formation is the real reason the fan circulates air continuously ... that and keeping the mice healthy.
frotosride
February 06, 2021, 08:37:01 pm »
For the longest time I thought I just had a constant blow through heat and AC system. I even thought I may have had a new rust hole I didn't know about... Imagine my surprise that is was all just a simple engineering design for my health and comfort!
blazer74
February 06, 2021, 10:06:23 pm »
If you don’t like the high blower all the time when in max mode, lever all the way cold activating the internal switch.
Remove the single orange wire from the blower speed switch and it will have all the speed settings.
The extra wire defaults the switch to high when in max on your 74 year.
February 07, 2021, 06:55:35 am »
Max is intended to be used to get to the desired temp more rapidly and then you should switch to the fresh setting.
