Author Topic: Steering lock pin  (Read 6804 times)
Offline MacQueen7
Steering lock pin
« on: February 06, 2021, 09:40:57 pm »
I have a standard shift tilt wheel with lights and wipers on the stalk, I replaced the turn signal switch and headlight switch.  The spring that moves the locking pin into the plate was broken.  I replaced the rack and the spring but I can’t get the pin to slide out when the key is switched to off.  Anyone have a picture of the proper install?  Or ideas?
Re: Steering lock pin
« Reply #1 on: February 07, 2021, 07:25:09 am »
Sounds like you don't have it clocked correctly. Time to take it back apart.
Offline MacQueen7
« Reply #2 on: February 07, 2021, 08:04:26 pm »
Little spring that goes in the gear for the rack wasn’t right. Found this on another thread after searching with my computer.     http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf
