The Lows (Lowering/Drops)
Figuring Rear Drop
Topic: Figuring Rear Drop (Read 18513 times)
Green9088
Figuring Rear Drop
February 24, 2021, 03:17:49 pm »
Hey guys,
I have an 87 C10 (R10), the previous owner did a bang up job buy heating the old springs and then flipped it.
I just did 3" Drop Spindles in the 2" drop springs in the front, I am trying to figure out what to do in the back for new leafs. Wanting it to be level and note sure what new leafs to get. whether it be 2" drop leafs and then flip it with a shackle? IF that will be level for the front,
I can figure the geometry, considering it be 2" drop leaf without the flip and what it would equate to after the flip
Any help would be great?
Re: Figuring Rear Drop
February 24, 2021, 06:22:39 pm »
Are you on a budget? Lots of options....
Green9088
February 24, 2021, 11:47:38 pm »
Not really on a major budget. Just trying to figure out what to do for the rear leafs, the front is 5” of drop between the spindle and springs. To make it level from my research it looks like I need to do a drop of 6” if it were at factory ride height.
Right now it ha a flip on it but the previous owner heated up the spring and bent it. I will attach a picture.
What I am thinking is get a 2” drop leaf and because it is flipped I could probably sit level with a oe shackle. But I am seconding guessing the math
February 25, 2021, 04:43:44 am »
Sounds like some new leaves and the axle flip will do the trick. Adjustable shackles may be needed as well.
1984Texaswidebody
February 28, 2021, 04:45:36 am »
Green9088,
Attached are some pics for reference. Front: 3" drop spindle, 2" drop springs Rear: Axle flip with factory springs.
Green9088
February 28, 2021, 11:26:03 am »
So the flip kit leveled out the back with the 5” front. Any recommendations on a replacement rear leafs? Seeing those pictures I am leaning to trying to find some oe replacements and just flip and shackle.
My thought process was a 3” drop leaf in the back with a flip would take me down in the back 6ish” bringing it level. But it seems just the flip and shackle does the job.
Chevynut73
March 04, 2023, 09:01:40 am »
Great looking Truck!
Question - you have any issues with tire rub during turns?
Thanks
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Shifty
I bleed Bowtie red...
March 06, 2023, 08:44:03 am »
Hey 84TexasWideBody, that is a great-looking machine!
98 C2500 ext cab longbed
Figuring Rear Drop
