73-87 Chevy & GMC Trucks
Heater to engine hose leaking
Topic: Heater to engine hose leaking (Read 8412 times)
shinkle
March 14, 2021, 07:34:18 pm »
I'm having a hard time finding a replacement hose. Its the hose from the heater to the engine, half rubber and half aluminum. The aluminum end attaches to the engine behind the air filter. Any suggestions for a source?
Attached a couple pics I stole from another user to show the hose
87 Chevy R10
5.7l
TBI
With AC
Last Edit: March 15, 2021, 01:24:03 pm by shinkle
1987 R10 5.7L TBI
Shifty
I bleed Bowtie red...
Re: Heater to engine hose leaking
March 15, 2021, 09:46:13 am »
I'm assuming that you're trying to keep it 100% OE? If not, simply cut the factory shell off, clean the end of the aluminum tube, and use universal heater hose and the hose clamps of your choice.
98 C2500 ext cab longbed
shinkle
March 15, 2021, 11:21:36 am »
I would like to keep it original. I'm not familar with the aluminum attachment to the engine, I assumed it was threaded and a standard rubber hose end would not work.
1987 R10 5.7L TBI
Mike81K10
Site Supporters
March 15, 2021, 08:06:06 pm »
If you cannot find the hose, you can have one made by using your old one as a template. You can search the Web to find a company to do it for you. They are out there and perhaps even local.
JohnnyPopper
Old Goof
March 16, 2021, 04:22:45 pm »
Look at the garbage the factory spewed on the firewall!
They had no shame, or should we say, Pride?
1980 C-10 under construction
March 16, 2021, 06:10:27 pm »
The rubber hoses attaches to the pipe and is crimped with a hose shell ferrule using a crimping tool. Quite an investment if you don't have the tools. If you are bent on keeping the factory pipe, cut the shell off and remove the leaking hose. Replace with a new one. You can use a heat shrink clamp if you don't want to use a conventional style clamp.
https://www.mcmaster.com/heat-shrink-hose-clamps/
Gates 19023
shinkle
March 16, 2021, 07:06:25 pm »
Nice, thanks.
1987 R10 5.7L TBI
