Author Topic: Removing Selectro Hubs  (Read 16942 times)
Offline Rcf
« on: March 16, 2021, 05:24:23 pm »
I am having a rather difficult time (stumped actually) getting the Selectro front hubs off in order to replace the rotors on my '83 K30.  Would appreciate any insight into what I need to do.
I did manage to remove the three screws and get the cap off, but that is where the road ended.
Any ideas?
Re: Removing Selectro Hubs
« Reply #1 on: March 16, 2021, 06:17:16 pm »
« Reply #2 on: March 16, 2021, 06:22:32 pm »
Also, depending on which ones you have on there and which axle is installed, you can look up the instructions on the hubs for assembly/disassembly, and then just follow the procedure for the wheel bearings and rotor swap.
Offline Rcf
« Reply #3 on: March 17, 2021, 12:35:55 pm »
Thanks, Vile.  I checked the manual, but did not find anything useful.  There is a lot of useful information in there that will be beneficial, though.  Perhaps a picture is indeed worth a 1000 words.
This is the hub and I have removed the metal spring steel ring that looked like it was holding things in.  No such luck.  I cannot see anything else that is removable.
« Reply #4 on: March 17, 2021, 05:02:37 pm »
Follow the instructions for the hubs and then follow the instructions for the wheel bearings and races.
https://milemarker.com/wp-content/uploads/2017/11/11034-instructions-scan.pdf
