Author Topic: Leaf spring eye bolt and bushing size...  (Read 8375 times)
Offline philo_beddoe
  • 77 C-10
« on: March 28, 2021, 03:41:43 pm »
Do I really have to go out and measure the inner diameter of the leaf spring eyes? One catalog says it’s either 1 1/2” or 1 3/4” (for ordering new bushings). Other catalogs don’t even mention the two sizes.
Re: Leaf spring eye bolt and bushing size...
« Reply #1 on: March 28, 2021, 05:16:41 pm »
What are you doing, poly bushings or rubber bushings? HD springs are 1.75"
  • 77 C-10
« Reply #2 on: March 28, 2021, 09:00:57 pm »
What do you suggest? I have 8 leafs, is that hd or standard?
Thanks...
« Reply #3 on: March 29, 2021, 04:29:54 am »
I would suggest you measure to be sure but you probably have HD springs.
Both have their advantages and drawbacks. Quality rubber bushings will behave like the factory system and I believe that is what you are after? BTW, they are not easy to change, so be prepared if you are doing them yourself.
  • 77 C-10
« Reply #4 on: March 31, 2021, 10:26:35 pm »
I will measure them for sure. Thanks for your help on this, will probably go with standard rubber.
  • 77 C-10
« Reply #5 on: April 27, 2021, 09:53:53 am »
What part of the job makes them “not easy?”
« Reply #6 on: April 27, 2021, 02:59:24 pm »
They are pressed in and don't just pop out. Same with the shackles. For the shackles, you may just want to get new ones.
  • 77 C-10
« Reply #7 on: April 27, 2021, 03:09:49 pm »
Agreed, it’s a lot easier for me to press the “place order” button than end up with bloody knuckles. Lol
