Author Topic: Grille swap help needed  (Read 5985 times)
Offline GMJager
« on: April 30, 2021, 01:35:18 pm »
So the current grille on my ‘77 k10 is the billet/bar type grill (first picture) and is attached with the bracket seen in picture #2. I’d like to install the grill in the third picture.. here’s the problem, after removing the old grill, there is nothing to attach 4 of the 6 bolt holes to with the new grill. Only places for screws/bolts are circled in green on the center support/hood latch mechanism, where it lines up, the other four spots have nothing behind them (picture 4). Final two pictures are what i have behind the grille
This is a ‘77 K10, and supposedly this is a grill for a 77, and all diagrams I’ve seen have the same attachment points, but i can’t seem to find any grill supports or brackets. What’s the deal here?
« Last Edit: April 30, 2021, 06:19:48 pm by GMJager »
Re: Grille swap help needed
« Reply #1 on: April 30, 2021, 02:56:33 pm »
Why don't you show us a pic of the radiator support with the grille removed so we can see what you have going on in there.
Offline GMJager
« Reply #2 on: April 30, 2021, 03:04:37 pm »
I thought i had one on my phone, but apparently not... I’ll get one after work!
« Reply #3 on: May 01, 2021, 08:17:45 pm »
Looks like you are missing the grille brackets that bolt to the radiator support. Can't tell from your small pix if the inserts are there for the other holes.
https://www.classicindustries.com/shop/all-years/chevrolet/truck/parts/exterior-trim/grill-components/grill-mounting-brackets/
Offline GMJager
« Reply #4 on: May 01, 2021, 08:23:24 pm »
There are two holes on the center support/hood latch mechanism that line up, inserts are there. Then the core support where the billet grille brackets were bolted on, 3/4 inserts are there. I assume that’s what you’re talking about?
Thanks for your help!
« Reply #5 on: May 01, 2021, 08:29:05 pm »
Okay, so click that link and order yourself the brackets, the nylon inserts, screws and you'll be golden
Offline GMJager
« Reply #6 on: May 03, 2021, 06:46:11 am »
Thanks for the help! It was driving me crazy not being able to find those brackets!
