Author Topic: 383 stroker timing  (Read 3253 times)
Offline Trucker2k16
383 stroker timing
« on: May 10, 2021, 08:06:53 am »
Hello everyone i am in need of some help i have a 383 stroker with a howards 180305-08 cam 229/229@50 282/282 480/480 i understand a bigger cam will want more initial im wanting to double check as ive not had a cam this size before so im at 36 total which i have 18 initial
Re: 383 stroker timing
« Reply #1 on: May 10, 2021, 02:39:38 pm »
Yes, your baseline setting should be 36° at 3500 RPM, vacuum advance disconnected. Advance and dial in as needed from there.
Offline TexasRed
« Reply #2 on: May 10, 2021, 07:16:06 pm »
Which cylinder heads, do you have a vacuum advance unit?
