Author Topic: What lies beneath….  (Read 4068 times)
Offline philo_beddoe
  • 77 C-10
What lies beneath….
« on: June 02, 2021, 03:47:22 pm »
I never knew what was under 40 years of crud. I think the first application was a Ziebart rustproofing done a long time ago, which is probably what saved the truck as there was nearly no rust when I bought it for $4500 about 6 years ago.
When I got the truck I sprayed tons of oil, wd40, lubricants, fluid film, you name it, I soaked everything. Then I recently installed both front brake calipers and discovered nearly 1/4 inch thick of pure solidified gunk. Sure it was protecting the metal, but why? Since we finished an almost frame-off restoration, the truck has not even seen water, let alone winter salt. So recently I went through 5 cans of engine degreaser in the entire engine bay and undercarriage and steam pressured washed it all off. But I had no idea about the rear wheel wells. I discovered the pure factory metal sea-mist green paint.
Now that it’s all clean, is there something I can put on there that’s non petroleum based? Maybe a light coat of truck bed liner spray? Or should I leave it be? How about a very light mist of wd40 just to protect the metal?
Here are the before and after photos.
« Last Edit: June 02, 2021, 04:15:45 pm by philo_beddoe »
Offline Mr Diesel
  • Aaron
Re: What lies beneath….
« Reply #1 on: June 02, 2021, 04:47:38 pm »
It already has paint on there. Paint protects metal from rusting....
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
« Reply #2 on: June 02, 2021, 06:48:26 pm »
Agreed, leave it unless you are exposing it to salt.
Offline MY1978
  • Just a girl and her truck since 1978
« Reply #3 on: June 03, 2021, 03:09:56 pm »
I have used Eastwood products and have been very happy with them.  Getting ready to knock down the rust on the underside and spray with internal frame.
https://www.eastwood.com/
Offline Scott91370
« Reply #4 on: June 15, 2021, 10:16:18 am »
WD40 will attract dust and dirt causing what you had.  Honestly spraying if off once or twice a year with a pressure washer, making sure to get into all the small areas, would be just fine.
  • 77 C-10
« Reply #5 on: July 01, 2021, 04:24:36 pm »
I’m leaving it alone and just gonna check under there now and then, should be fine.
