Author Topic: 85 K10 - Shorty Headers with Stock Y-Pipe & Exhaust  (Read 14696 times)
Offline kuhnzoo
« on: June 09, 2021, 01:12:58 pm »
Hey everyone. I have an '85 K10 350 AT NP208 long bed. It is stock except for the 350 I am transplanting for the 305.
The 350 is a '92 block .030 over. I built this with a mild cam (Summit K1102) and GM vortec heads, edelbrock 2116 vortec intake and QJet. I planned to use stock exhaust manifolds, heat riser valve, y-pipe and other exhaust components for simplicity. I am not planning to run a dual exhaust. This is not a high performance truck.
I recently discovered that the stock passenger side cast iron exhaust manifold will not mount to the head since the vortec heads do not have the additional outermost drilled/tapped hole on what is the #8 cyl exhaust port (or #1 cyl when mounted on the driver side). Thought I had done my research, but I was not thorough enough. So now I have a bunch new exhaust components (cast manifolds, Y pipe, muffler, other exhaust piping) that I can't use.
Has anyone used shorty headers that allows the stock 1985 K10 exhaust system (that I have) to bolt up? Basically swapping the cast manifolds (and heat riser valve) out for the shortys. I have searched the forum and googled and duckduckgo'd, but did not see someone that has done this exact swap (or I missed it). I have seen someone using 88-95 shortys in a 86 K20, but I am not sure if those shortys bolted to their stock y-pipe (uses the same Y-Pipe as my 85 K10) or something custom.
If you know of a set of shortys that will allow my stock y-pipe (Walker 40412) to bolt up, please post up brand and part number of shortys. Thank you.
1985 K10 350CID A/T
Re: 85 K10 - Shorty Headers with Stock Y-Pipe & Exhaust
« Reply #1 on: June 09, 2021, 03:45:59 pm »
I don't think you are going to find shorty's that match that manifold discharge port without modifying the Y-pipe. The correct exhaust manifolds are close but will still require modifying the Y-Pipe as well. So either way, you are going to need to do some exhaust modifications.
« Reply #2 on: June 09, 2021, 03:46:47 pm »
This shows the stock manifold vs a 98 chevy stock manifold
Offline kuhnzoo
« Reply #3 on: June 09, 2021, 05:44:31 pm »
Thanks for the feedback. I was afraid that was the case. Just wanted to be sure since I have the new components for the stock 85 exhaust.
Looks like it will be something custom with shorty headers or see if 1990 full size Blazer exhaust manifolds and exhaust system would work since it uses a passenger side drop transfer case and a driver's side y-pipe.
Decisions, decisions...
Sent from my Moto G (5S) Plus using Tapatalk
1985 K10 350CID A/T
