Author Topic: Frame number on a 1973 GMC 3/4 ton  (Read 8020 times)
Offline MMikeJBenN27
« on: June 22, 2021, 06:20:52 pm »
I have a 73 GMC 3/4 ton that I had bought for parts, so I didn't register it.  Much later, I decided to fix it up and make it a running driving vehicle.  Problem is, I put another cab on it, (the original was rusted, as many 73s are), so there is no VIN on it, and my paperwork was lost in a garage fire.  I can't for the life of me find the VIN number on the frame.  I have been told that it is on the driver's side rail under the cab, that it is on the right side, that it is just ahead of the right-rear cab-to-frame mount, that it is just ahead of the the left-rear cab mount, and I have looked in all those places, but I can't find it anywhere.  I have unbolted the cab and raised it up and used a mirror, and STILL can't find it.  HELP!
Mike
Vallejo, California
MMikeJBenN27@outlook.com
PS:  When I got this truck, it was an automatic, but I put a manual trans in it.  Could the numbers I am looking for be under the transmission crossmember on the driver's side?
« Last Edit: June 22, 2021, 08:06:01 pm by MMikeJBenN27 »
Re: Frame number on a 1973 GMC 3/4 ton
« Reply #1 on: June 22, 2021, 08:05:16 pm »
Did you save the vin plate off of your old cab? Look by the steering box on the frame rail.
« Reply #2 on: June 22, 2021, 08:07:17 pm »
I had saved the vin tag from the rusted cab, but it has vanished.  You think the numbers are near the steering box?
« Reply #3 on: June 22, 2021, 08:17:22 pm »
I FOUND IT!  THANK YOU, THANK YOU, THANK YOU!
Mike
« Reply #4 on: June 22, 2021, 08:21:48 pm »
Look hard for the VIN plate and hopefully you find it.
« Reply #5 on: June 22, 2021, 08:44:07 pm »
I have torn the house apart, and so far, still can't find it.  I sure hope I do.
Mike
« Reply #6 on: June 23, 2021, 05:53:29 am »
Check the right hand drawer of your tool box
