Author Topic: O2 sensor hole size and thread  (Read 5648 times)
Offline Stewart G Griffin
« on: July 13, 2021, 08:49:39 pm »
Would anyone happen to know the O2 sensor hole size and thread type for 87 and up trucks?
This is is on the exhaust "Y" pipe nearest to the left exhaust manifold.
Offline dusterdude
Re: O2 sensor hole size and thread
« Reply #1 on: July 14, 2021, 04:26:08 am »
I believe its 18mm,not sure of pitch.its the the same size as an autolite spark plug for a 60's model ford.number 86,I think.
Sent from my LM-X420 using Tapatalk
« Reply #2 on: July 14, 2021, 05:19:02 am »
O2 bungholes are 18mm x 1.50
« Reply #3 on: July 17, 2021, 11:20:50 am »
Good.  Thanks.
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: July 17, 2021, 12:16:10 pm »
It's M18 x 1.5.
98 C2500 ext cab longbed
« Reply #5 on: July 17, 2021, 06:46:54 pm »
It's M18 x 1.5.
Great.  It seems like the aftermarket A/F gauges also come  with 18mm X 1.5 sensors.
The reason i asked was because i was thinking about getting an air fuel ratio gauge in order to try to solve this carb problem.   And my Y pipe already has the factory hole and plug.
But i think i may try vacuum gauge first.
Offline Shifty
« Reply #6 on: July 19, 2021, 09:29:00 am »
A/F meter is a great tuning tool!
« Reply #7 on: July 19, 2021, 06:52:51 pm »
Using an O2 sensor to tune an engine is only worthwhile when the engine is 100% spot on running perfectly. Remember an oxygen sensor senses oxygen, not carbon monoxide, not CO2, not hydrocarbons etc. A cylinder misfire results in unburned fuel and air so your oxygen sensor will see high O2. Are you going to assume lean because of this? O@ sensor tuning is only for fine tuning a properly running engine. Using it to diag a drivability issue will send you down a rabbit hole. Since you are carbureted, don't bother. Fix your timing and then play with your carburetor.
