Author Topic: Axle ratio conundrum  (Read 8757 times)
Offline MY1978
  • Just a girl and her truck since 1978
« on: July 19, 2021, 05:26:49 pm »
I want to change the fluid in my rear diff (even a girl can do this!!! ;D)  as I cannot remember if, or when, it has ever been changed (I am sure it has over 43 years at some point).   I always was told it had limited slip, how do I figure out if it does or doesn't because I know that if it is limited slip, I need to use an additive.
So here is the conundrum......it was ordered with a 4.11 ratio, the RPO build list has it at a 3.40 ratio and on the diff there is a GM8 which when I look it up says that is for a 2.56 ratio.  So, how do I know WHICH I have?  There are a series of numbers like a serial number on the diff.  There is no tag attached to any bolt.
HELP!!!!!
« Last Edit: July 19, 2021, 07:38:21 pm by MY1978 »
Re: Axle ration conundrum
« Reply #1 on: July 19, 2021, 06:48:04 pm »
When you remove the cover, the ring gear will have the high and low number separated by a colon. the formula is always driven over drive:
43/14 = 3.07 (:1)
Offline LILT77
« Reply #2 on: July 19, 2021, 06:50:18 pm »
With all the different ratios you mentioned the only way to know for sure what ratio you have is to remove the cover and count the ring gear and pinion teeth and divide them. Ex. 37 ring gear teeth divided by 9 pinion teeth = 4.11 ratio. Also, since you have to remove the cover anyway you will know right away if you have a limited slip or not.
77 C10/Big 10 Cheyenne "Old Blue"
81 C2500 Sierra Grande "Gramps"
Offline MY1978
Re: Axle ratio conundrum
« Reply #3 on: July 19, 2021, 07:39:06 pm »
Thanks, the adventure starts tomorrow.
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: July 20, 2021, 09:35:29 am »
Another easy way to tell (before the cover is off), is to jack the diff into the air, with transmission in neutral and brake off, and spin the right side wheel.  If both wheels turn the same direction, it's posi.
98 C2500 ext cab longbed
