Author Topic: 700r4  (Read 7099 times)
Offline ChevyGuy
700r4
« on: January 09, 2007, 03:13:00 pm »
I got a 700r4 from my father in law that got a 87 burb it was in. Theres something wrong with the tranny but i was wondering how hard is it to rebuild one and what instruction manual would be the best at showing me how to do it?
Offline joesgarage71
  • Wrench
Re: 700r4
« Reply #1 on: January 09, 2007, 06:50:00 pm »
There are several books and videos on rebuilding tranys,I've seen some at summitracing.com, there more or less all the same. If you have basic mechanical ability it should be too stressful. The first 400 (475) I rebuilt over 15 yrs ago is still going strong, and it lives behind a 500Hp 454.
Steve
ATSG
« Reply #2 on: January 09, 2007, 07:50:00 pm »
Offline ChevyGuy
tools
« Reply #3 on: January 09, 2007, 09:43:00 pm »
Is there any special tools that are needed for rebuild or tear down? Also I was looking on Ebay and they have 2 different books on certain year models. Is there a difference? The tranny I got came out of a 87.
cgi.ebay.com/ebaymotors/w...404&rd=1,1
Re: tools
« Reply #4 on: January 10, 2007, 05:02:00 am »
yes there are a few special tools you will need.
You can improvise and make a trans pump puller easily, you can easily make a seal installer with some mig wire and a piece of 1/4 brake line, but you will need a piston compressor like this
feeler gauges, trans gel or vaseline, organization and a clean bench. If you have an old stool, cut a hole in the middle and it will make a great stand too.
  • Wrench
Re: tools
« Reply #5 on: January 10, 2007, 09:56:00 am »
I used two c clamps and little blocks of hardwood instead of that device.
Re: tools
« Reply #6 on: January 10, 2007, 05:47:00 pm »
The problem with that is you can't change the low reverse clutch piston seals inside the unit very easily and you risk damaging the return spring plate. I have a bench mounted design like this that works great for out of unit service
www.bulkpart.com/Merchant...ct_Count=1
I also have this one
www.bulkpart.com/Merchant...ct_Count=3
And this one I used most often... It works great for internal unit service. I've also used it for several other things other than automatic transmission work. :D
http://www.otctools.com/products/detail.php?id=1779
Edited by: VileZambonie  at: 1/10/07 5:51 pm
Offline ChevyGuy
Re: tools
« Reply #7 on: January 14, 2007, 11:41:00 pm »
On that tranny they are showing 2 books one for 82-86 and the other 87 and up. The only numbers i could find on it was 8663549. Im just trying to figure out the year so i can get the right book. Anyone know how i can find out what year model tranny i got?
Re: tools
« Reply #8 on: January 15, 2007, 02:38:00 pm »
Offline ChevyGuy
id number
« Reply #9 on: January 17, 2007, 02:29:00 pm »
I found the id number on the tranny. It reads 7TUM203H.
Im guessing its a 87 model? TU means a truck, 203 is the date in the year it was made and H im not for sure.
