Author Topic: Fuel System Picking up Air  (Read 17222 times)
Offline Ben w
« on: August 31, 2021, 09:48:15 pm »
Initially I did not know what was wrong with my fuel system, only that my truck was spitting and sputtering more and more frequently. I started out by rebuilding my Quadrajet Carburetor and replacing the fuel pump that already appeared to be new from the previous owner. I also replaced the fuel tank selector valve. At one point in the early summer when things first started to get particularly hot, I thought that maybe I was experiencing vapor lock. Based on that, I bypass the steel fuel line that runs inside of the frame and ran a rubber fuel line from the back of the truck to the engine compartment. When that did no good, I went back to the steel fuel line and also replace my carburetor with a new Edelbrock AVS2. While tuning the new carburetor I noticed that air was bubbling up into the fuel filter. I replaced the fuel selector switch a second time and changed to an electric fuel pump up in the engine bay. Today I moved the electric fuel pump to the back of the truck, just in front of the tank selector valve but air is still getting introduced into the line. Do I just need to replace the sending units? I have replaced every piece of rubber hose between the tanks and the carburetor as well. The sending units seem to be kind of a pain to get a hold of and frankly I really want my truck running this weekend. Is there something else that I'm missing? I would think that if the issue was a hole somewhere in the system, it would be leaking fuel now that the pump is at the back of the system. That's simply does not seem to be the case. Any thoughts would be appreciated.
Re: Fuel System Picking up Air
« Reply #1 on: September 01, 2021, 04:26:54 pm »
Have you tried removing the gas cap? Is the tank properly vented?
Offline prider5
« Reply #2 on: July 07, 2026, 07:23:22 pm »
Sorry to reply on a post this old - I'm experiencing the same problem, did you ever figure out what your issue was?
« Reply #3 on: July 07, 2026, 07:47:59 pm »
The OP hasn't been back on the forum since he posted the thread in August 2021.
What year/model truck?  What engine?  Carbureted or injected?  Naturally aspirated or forced induction?  Have you tried Vile's suggestion yet?
Offline prider5
« Reply #4 on: July 10, 2026, 06:01:43 pm »
Thanks for letting me know bd! I can make a new thread if you'd like.
Truck is 1977 K20, with a lot of parts from a 1980 K10. 350 SBC with a 1906 carb, and has dual tanks.
I've been rebuilding the truck, so it currently has 2 new fuel senders (dorman iirc), new tank switching valve, and just recently put a new mechanical fuel pump on (after having fuel delivery issues). I thought maybe the hard line had a hole somewhere, so I recently ran new rubber line from the switching valve up to the engine and made sure I ran it away from heat (thought it was potentially vapor locking), and back when I put the sending units in I ran new rubber lines before the valve as well.
I have a clear filter after the fuel pump before the carb, and I can see it pump fuel well when I first start it, and then after 10 minutes or so of driving the filter runs dry, with what looks like a lot of air bubbles flowing in as it runs out. Been struggling to figure out what the issue is, contemplating just putting an electric pump on it, but it would probably need to be after the switching valve, and I know they are notorious for not wanting to pull fuel and going out, so not sure. I think I tried it without the cap on as Vile suggested, but it's been a bit now and I'm struggling to remember for sure ha. I'll try this weekend if I can find the time to go and test.
« Reply #5 on: July 11, 2026, 01:09:33 pm »
So the truck isn't running at all or or is missing and sputtering?  Not really sure what issue you are having.
Offline prider5
« Reply #6 on: July 12, 2026, 06:31:07 pm »
It starts up fine, getting 6ish psi at the carb, runs good, no issues. After driving for about 10-15 minutes, it starts to starve for fuel. It usually won't completely die if I use very little throttle, but the pressure drops to 0-1 and I can see that the clear filter near the carb is emptying of fuel. Initially I thought it was vapor lock (even though it felt like it was happening very quickly to be that), so I rerouted the fuel lines away from heat. I also replaced the pump because it was weeping, still have the issue.
« Reply #7 on: July 13, 2026, 11:13:46 am »
Heed Vile's suggestion and remove the fuel tank cap, then drive it for 30+ minutes or well past the time that symptoms typically appear.
Offline Scaryfastatx
« Reply #8 on: October 15, 2026, 09:13:41 am »
sounds like you are having similar issues to me with a weak pump. Cold it was fine, but then as the engine warmed it the pump started to thermally expand and it started pumping very little. Curious what brand/pn pump you have?
Offline JohnnyPopper
  • Old Goof
« Reply #9 on: October 16, 2026, 07:47:39 pm »
"so it currently has 2 new fuel senders (dorman iirc)"
What does that mean? Internal fuel pumps in the two tanks? If yes, AND a mechanical?
(This doesn't happen very often) Yo bd, that would be 'caps'  ;D ;D ;D
If no to the first Q's, just go electric with a pressure regulator. Done and Done!
1980 C-10 under construction- GONE!
