Author Topic: water leaking under dash when it rains?  (Read 4115 times)
Offline Metal Man
« on: September 08, 2021, 07:55:58 pm »
My Floor board is soaked after a rain. Any ideas where to start? Looks to be coming from behind the air control box behind the glove box. What is need to repair?
Re: water leaking under dash when it rains?
« Reply #1 on: September 09, 2021, 06:06:14 pm »
A garden hose and a flashlight. Have an assistant spray isolated areas while you observe. Most common leaks come from, failed seam sealer in the cowl and or rust, missing or failed cowl seal, associated grommets etc (points of entry on the firewall), and windshield area leaks. Good luck
