Author Topic: No Headlights, Taillights, Horn, or Gauges  (Read 4479 times)
Offline 4wdmemes
« on: September 30, 2021, 09:54:25 pm »
Hello all, today I started up my 1984 K10 LWB and noticed that I have no headlights, taillights, sidemarkers, interior lights, or horn. Although when I press the brake, the brake lights work, so no burnt bulb. And the turn lamps work when I use the turn signals. Any help is appreciated, 1984 diagrams would especially be helpful. ;D
Offline bd
Re: No Headlights, Taillights, Horn, or Gauges
« Reply #1 on: October 01, 2021, 10:56:47 am »
The 1984 Wiring Manual is available along with all the other manuals in our Technical Forum.
Number 1157 (and the subsequent 2057) bulbs have dual filaments.  The brake/turn signal lamps and running lamps employ separate filaments within the bulbs.  So bad bulbs remain a possibility until physically verified.
Using an incandescent test light, is the alternator #2 regulator terminal constant 12 volts?  Check the fusible links and connections to the starter solenoid 3/8" B+ stud.
Offline Susipfm
  • New Users
« Reply #2 on: May 29, 2022, 08:55:16 am »
I am having the same issue, I found a cab to frame ground strap broken, ordering a new one to see if that is the problem, I'll keep you posted
Sent from my SM-A125U1 using Tapatalk
