Author Topic: 1987 Silverado 5.7 Part  (Read 10602 times)
Offline CarlosSJCA
« on: October 15, 2021, 03:24:41 pm »
Where does this go? Took truck apart 10 years ago forgot where it goes? Picture kinda shrunk it actually longer.
« Last Edit: October 15, 2021, 03:30:00 pm by CarlosSJCA »
Offline fitz
Re: 1987 Silverado 5.7 Part
« Reply #1 on: October 15, 2021, 05:04:06 pm »
I'm guessing the steering column?
Hopefully someone that knows will chime in soon.
« Reply #2 on: October 15, 2021, 05:18:32 pm »
If it's about 2" in diameter and 3" long, it is a heat shield for the engine oil pressure sender.
Offline CarlosSJCA
« Reply #3 on: October 16, 2021, 05:49:58 pm »
I do not think it goes around sender. I think it is a heat shield going down right side rear near exhaust?
Offline calif phil
« Reply #4 on: October 16, 2021, 08:30:41 pm »
Yes it’s the heat shield for the oil pressure sending unit.   I changed my OPS not too long ago on my ‘87 and it was exactly like that.
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: October 16, 2021, 09:36:56 pm »
Did they change the location of the sending unit that year? Historically to the right of the distributor.
1980 C-10 under construction
Offline calif phil
« Reply #6 on: October 16, 2021, 09:49:20 pm »
Yes they did. I crawled under the drivers side and it was right by the exhaust manifold.  Hence the need for the heat shield.
« Reply #7 on: October 16, 2021, 11:24:15 pm »
The 1987 dash gauge OPS threads into the left side of the block down near the oil filter, adjacent to the exhaust.
Offline CarlosSJCA
« Reply #8 on: October 16, 2021, 11:43:46 pm »
Ok thanks I will look in to it.
« Reply #9 on: October 17, 2021, 06:40:13 am »
 8)
  • Old Goof
« Reply #10 on: October 17, 2021, 12:50:30 pm »
is it me, or does FRT> indicate the front of the engine?
If so we must be looking at a Chrysler, no?
Or maybe it's missing a letter, like A... ::)
« Reply #11 on: October 21, 2021, 07:02:29 pm »
When you fart near the front of the engine, the fan will carry the smell in the direction of the arrow.
  • Old Goof
« Reply #12 on: October 21, 2021, 07:50:29 pm »
Ah right?! Into the Fart Receiving Tunnel!!
Good one VZ!  8)
Offline frotosride
    • WFO CONCEPTS
« Reply #13 on: October 27, 2021, 02:13:36 pm »
What other site can you find true wisdom and insight on our special vehicles...
