Author Topic: Mechanical Temp sensor and guage???  (Read 7998 times)
Offline JohnnyPopper
  • Old Goof
« on: October 21, 2021, 08:02:19 pm »
Getting ready to drop the motor in the "80 C10, looks like the sensor had a coil coming from the part that looks like a thermocoupler.
It's about 3/8 diameter screwed into a larger brass fitting that matches the head opening
The gauge has the same type of coiled wire.
Was this stock? In calling/looking for a replacement all I see are electric sensors.  ???
Brain trust! Where are you???
1980 C-10 under construction- GONE!
Re: Mechanical Temp sensor and guage???
« Reply #1 on: October 21, 2021, 08:22:05 pm »
Someone swapped in a mechanical gauge.  The original was electric.
  • Old Goof
« Reply #2 on: October 22, 2021, 02:24:44 am »
Wow, why would they do that???
Thanks bd, any info on where/when they used mechanical? Just curious?
Were they cheaper? More of a PIA in my opinion.... ::)
« Reply #3 on: October 22, 2021, 10:39:20 am »
Regarding light-duty GM trucks, OEM pre-1978 oil pressure gauges were mechanical; all the remaining factory installed gauges (save for the speedometer) were electric from 1967 forward.
Old school thinking, perhaps.  Generally, good quality mechanical gauges are a little more accurate than the factory installed electric gauges with greater scale detail.  Someone may have experienced cooling issues and didn't trust the OEM gauge.  Or, maybe they were enticed by some "cool" or "high performance" factor, because of the greater detail in the temperature indication.  The factory electric gauges are accurate to ± ~7%, so the swap wouldn't have been grossly beneficial.
  • Old Goof
« Reply #4 on: October 22, 2021, 01:05:21 pm »
You solved the mystery bd! It's hooked up to an aftermarket gauge that has a greater scale.
Wow, all that work for what?  ::)
Can't wait to throw it away... 8)
« Reply #5 on: October 22, 2021, 07:44:28 pm »
People are dumb and do lots of dumb things, especially to vehicles. These trucks were a prime target for it all. Basically, open a JC Whitney catalog from 1989, and here we have it.
  • Old Goof
« Reply #6 on: October 22, 2021, 10:19:43 pm »
Understood- "if you find a holy cow, milk it for all it's worth"
