Author Topic: C30 Wheel Cylinder  (Read 5173 times)
Offline 86LG4T5
C30 Wheel Cylinder
« on: October 25, 2021, 05:10:22 pm »
I need to replace the wheel cylinder inside the drum brake.  I have it torn down to the backing plate.  I can't get at where the brake line connects behind the backing plate because of the huge leaf spring in the way.  Is there a trick?  Thank you!!
Offline 86LG4T5
Re: C30 Wheel Cylinder
« Reply #1 on: October 25, 2021, 06:01:30 pm »
I ended up taking out the bolts that hold on the backing plate and pulled it forward to give me room.
« Reply #2 on: October 25, 2021, 06:03:04 pm »
Crack the line loose, unbolt it, slide it forward, hold onto the line with a flare nut wrench and spin it off.
