Author Topic: Single wire 6 port fuel valve  (Read 8470 times)
Offline CA Big Red
    • Big Red Squarebody
« on: October 26, 2021, 12:45:23 am »
ISO this single wire six port fuel valve selector.
I am understand now that this wasn’t something I wanted to have had break. I can’t just go get another one.
Anyone have any thoughts on how or where to go to pick one of these up. I’d prefer brand new…but I get that this might end up being a good used one.
any direction here would be appreciated.
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Offline LILT77
Re: Single wire 6 port fuel valve
« Reply #1 on: October 26, 2021, 05:10:12 pm »
Mine had the 3 port one before I removed it. Try looking up ACDelco #467513
77 C10/Big 10 Cheyenne "Old Blue"
81 C2500 Sierra Grande "Gramps"
Offline CA Big Red
« Reply #2 on: October 27, 2021, 09:39:18 pm »
But mine has six…
Offline CA Big Red
« Reply #3 on: October 27, 2021, 09:39:45 pm »
Offline CA Big Red
« Reply #4 on: October 27, 2021, 09:40:01 pm »
Offline LILT77
« Reply #5 on: October 28, 2021, 05:57:54 pm »
The part number I listed is for the 6 port
Offline CA Big Red
« Reply #6 on: October 30, 2021, 04:21:50 pm »
But nobody has it.
Offline dartresurector67
« Reply #7 on: February 07, 2022, 08:13:32 pm »
I had the same thing happen to me. I tried getting the modern FV5 motorized 6 port valve but gave up when I couldn’t get it to work with one wire. Ended up getting two 3 port solenoid valves from summit and just daisy chaining a positive line from the sending valve to the return valve and it worked great for the carb & mechanical pump.
However, the cheap 3 way valves are not rated for fuel injection pressures, so I had to circle back to the new modern valve. It was super easy to figure out, after I found this gem. Check this thread out.
http://www.barthmobile.com/eve/forums?a=tpc&s=7031072951&f=3431087061&m=4303955787&r=6213934197#6213934197
« Reply #8 on: February 08, 2022, 07:49:59 am »
Did you read any of the threads here on this subject?
http://forum.73-87chevytrucks.com/smforum/index.php?topic=37007.0
