Author Topic: How many horses ?  (Read 24636 times)
Offline Snag
How many horses ?
« on: November 27, 2021, 06:01:23 pm »
  I've been a member here for a couple (or more) years , but since my son had my truck ... Rojo Grande is an '86 GMC 1500 , 305 with a TH700R4 . The problems started when I let my son "borrow" it ... but that's another story for another day .
   Today , the story is that it ran out of oil and nearly seized - not his fault , broken oil pressure sensor dumped the oil . I've got the motor stripped some but still in the truck , and piston #1 is bumping the head  but that's also not what I wanted to ask .
   This is the "H" motor , supposed to be 9:1 compression with the 1.840 intake/1.5 exhaust valves and closed chambers . The Chilton manual sez this motor makes 165 Hp @ 4400 ... stock . I'm planning on an .030 overbore with stock .110 dished pistons , an Elgin E-922-P CAM (.444"/288° intake, .465"/298° ex) with an Edelbrock Performer or Torker intake , 1.25" diameter long tube headers and the stock Quadrajet . I'm also stripping most of what's left of the emissions plumbing and running some fairly quiet mufflers .
  My real question is how much can I reasonably expect to gain horsepower-wise from these mods ? Am I too optimistic to expect around 220 or so ? I'll also be swapping the original 2.73 rear axle gears for a set of 3.42's , which I expect will also add a little snap off the line without hurting mileage much - I'll be turning around 1750 at 60 MPH .
Offline JohnnyPopper
  • Old Goof
Re: How many horses ?
« Reply #1 on: November 29, 2021, 09:52:26 pm »
There will be some brainiac here that will help you do the math. It won't be me though 8)
Curious if you know the stroke specs of a 305 vs a 350. Longer strokes get their torque/HP at lower RPM's which it looks like your going to be at 60.
1980 C-10 under construction
« Reply #2 on: November 30, 2021, 05:53:07 pm »
Do not use a Torker II intake. Why bother with the 305 though, especially if it is in the condition you describe? Find a 350 and be happy.
Offline Stewart G Griffin
« Reply #3 on: June 12, 2022, 03:10:45 pm »
i think the  E-922-P cam would be a good choice-----won't give up too much bottom end while should get you over 200hp on the top end.  Might still be able to use the stock converter here?
i would use an edlebrock performer rpm if you're going to continue using the q-jet.
But really, switching to 3.42 from 2.73 alone, i think, will make a big enough difference.
Now, remember, i'm not an engine  person and my "advice" is free.......
Offline Mr Diesel
  • Aaron
« Reply #4 on: June 13, 2022, 09:41:13 am »
As already stated above, get a 350 and dump the 305. I have an H 305 in my Camaro. I rebuilt it .030 over, better cam, edelbrock intake and carb and put together a good tune. Basically what you are considering. I'm certain it is less than 200hp. I had good reasons for it at the time (trying to keep car original). I later regretted it and now I'm trying to wear it out so I can justify building a 350 for it.
Edit: I just realized this thread started in November of last year. Hope the OP got things worked out.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline peewee0413
« Reply #5 on: July 14, 2022, 07:24:51 pm »
I don't know about a stock converter....
Sent from my SM-S908U using Tapatalk
