Author Topic: help!!!newbee with a bad clutch?  (Read 5444 times)
Offline 73bucket
« on: February 01, 2007, 06:27:00 pm »
hi everyone i have a 73 c10 with a 350 and 3 on the tree.i suspect my clutch is out when i let out the clutch peddle it grinds and doesnt go.this is in all the gears except nuetral. do any of yall know if its the clutch? if so how hard is it to replace all i have is a floor jack can anyone help me out? thank yall.
Edited by: 73bucket at: 2/1/07 8:34 pm
Re: newbee with a bad clutch?
« Reply #1 on: February 01, 2007, 05:30:00 pm »
Do you mean you can't get it into any gears without it grinding? Does the truck want to move lets say if you started the truck up in 1st gear while depressing the clutch pedal?
Check your linkage adjustment
Offline 73bucket
« Reply #2 on: February 01, 2007, 05:32:00 pm »
i can put the shifter in gear without grinding but when i let out it grinds it like at first tries to move like a fraction
Offline 73bucket
« Reply #3 on: February 01, 2007, 05:34:00 pm »
i even unhooked the linkage and engaged it and still grinds
Offline DnStClr
« Reply #4 on: February 01, 2007, 08:43:00 pm »
It sounds like a bad throwout bearing, but to be sure  you might want to have a mech look at it. Pretty big job to replace a clutch. 5-6 hrs labor anyway. The engine and tranny have to come apart.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline roundedline
« Reply #5 on: February 02, 2007, 12:18:00 pm »
You have checked the linkage on the clutch right?  If it is adjusted correctly, then it is probably the pressure plate.
If you are mechanically inclined you can do the replacement yourself, but you will need to resurface the flywheel if you are replacing the clutch assembly.  the 3 speed isn't heavy at all.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 73bucket
clutch.
« Reply #6 on: February 02, 2007, 09:17:00 pm »
thanks. the clutch adjuster bolt i tried loosining and tightining a little and still grinds. if it was the tranny wouldnt it at least work in reverse? i was pulling away from a stop sighn when this happened in low gear.i did notice to that when i put it in reverse not running it tries to roll backwards in the drive way and the driveway aint very steep. before this reverse would hold it.
