Author Topic: oil pressure sender(this too!)  (Read 11230 times)
gpday06
  • Guest
« on: February 03, 2007, 01:24:00 am »
where is the oil pressure sender located, and also what temp. does the truck run off stock?, and where is that sender located?
Re: oil pressure sender(this too!)
« Reply #1 on: February 03, 2007, 08:00:00 am »
You should make one thread about this. Include year make and model. Do you have a gauge or an idiot light?
What do you mean what temp does the truck run off of?
Do you mean where is the engine coolant temperature sending unit? If so that is located in the LH cylinder head next to the exhaust manifold.
The oil pressure sending unit is installed in the back of the engine near the firewall on the LH side. Some also used and oil pressure switch and can be located next to the oil filter in the cylinder block.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: February 03, 2007, 11:42:00 am »
On my old 79 350 engine, it was right here....this is the back of the motor, near the distributor.
temp sensor....
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 2/3/07 11:49 am
gpday06
  • Guest
« Reply #3 on: February 03, 2007, 11:49:00 am »
its a '79 c10, so you guys actually answered my questions, thanks!
