Author Topic: 73 c10 clutch problem?  (Read 5457 times)
Offline 73bucket
« on: February 01, 2007, 09:38:00 pm »
73c10 when i let out the clutch peddle in any gear it makes a grinding sound and truck doesnt move it tries then grinds.is this the clutch doing this? if so whats a good way to remove tranny all i have is a floor jack. oh putting it in gear no grinding
Edited by: 73bucket at: 2/1/07 9:40 pm
Re: 73 c10 clutch problem?
« Reply #1 on: February 01, 2007, 08:46:00 pm »
Grinds in all gears = broken trans
Yes you can use a floor jack
Offline 73bucket
« Reply #2 on: February 01, 2007, 08:49:00 pm »
wow.what part are we talking about?
broke it
« Reply #3 on: February 02, 2007, 07:05:00 am »
If the clutch is engaging and disengaging the input shaft then the grinding will go away when you push in the clutch while it's in gear I'm assuming? Then you broke a gear on either the mainshaft or countershaft.
Offline joesgarage71
  • Wrench
Re: broke it
« Reply #4 on: February 04, 2007, 04:24:00 pm »
You could have ripped the center out of the clutch disc.You would get that grinding metalic sound.
Steve
Offline 73bucket
Re: broke it
« Reply #5 on: February 04, 2007, 07:11:00 pm »
thank you. i  was wanting to hear that. got a mechanic going to work on it soon as he can get to it .its been over a week now im going nuts. little longer i guess.
