Author Topic: LS SWAP 5.3.4L60E / 1976 K10 4X4 "NEED TRANSFER CASE ADVISE"  (Read 12775 times)
Offline jfkelley
« on: January 11, 2022, 09:05:42 pm »
I have decided to do an LS swap on my 1976 High Sierra K10 4X4 , I will be buying an complete 5.3 GEN 3 / 4L60E 4WD Transmission with ECM , Harness and fuse box   ..My question to the forum experts is what transfer case will bolt up to the 4L60e?...I would like a transfer case that is a manual shift linkage nothing electronic ...Thanks in advance ...
« Last Edit: January 11, 2022, 09:11:12 pm by jfkelley »
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Offline JohnnyPopper
  • Old Goof
1980 C-10 under construction
Offline ehjorten
Re: LS SWAP 5.3.4L60E / 1976 K10 4X4 "NEED TRANSFER CASE ADVISE"
« Reply #2 on: January 13, 2022, 11:14:32 am »
Advanced Adapters makes a kit that will adapt a NP205 (round bolt pattern - hard to find), NP208, or NP241 to a 4L60e.
https://www.advanceadapters.com/products/50-6901--gm-700r4-to-gm-np208-adapter-kit-replacing-th400/
-Erik-
Offline jfkelley
« Reply #3 on: January 18, 2022, 11:43:08 pm »
I finally found an NP 241C ..What adapter do I need to attach it to the 4L60e ?
Offline ehjorten
« Reply #4 on: January 19, 2022, 09:43:32 am »
Call Advanced Adapters. They should be able to help you.
-Erik-
« Reply #5 on: January 19, 2022, 04:17:06 pm »
The stock adapter will work for one of these trucks with 700R4/4L60 and NP208/241
Offline jfkelley
Offline jfkelley
« Reply #8 on: January 20, 2022, 08:52:05 pm »
Thanks @ VileZambonie I just purchased the adapter .. I have a 5.3/4l60 out of a 2005 truck with a 241 t/c out of a 91 suburban with vss.I am wanting to wire up the vss and the 4 w/d so the pcm knows when its in 4-low..But have also thought about a switch on the transfer case shift lever its self or even a toggle switch mounted remotely. Has anyone have experience with this?
« Last Edit: January 21, 2022, 06:26:16 pm by jfkelley »
