Author Topic: FUEL TANK QUESTION LS SWAP  (Read 11043 times)
Offline jfkelley
« on: February 20, 2022, 06:57:23 pm »
Where can I find an 1987 TBI Fuel tank with electric fuel pump sold as a kit ready to install for my 76 K10 4x4 wanting to keep it EFI ..Do we have a vendor on here that sells them?...Any advice will be greatly appreciated
« Last Edit: February 20, 2022, 08:39:47 pm by jfkelley »
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Offline dusterdude
Re: FUEL TANK QUESTION LS SWAP
« Reply #1 on: February 21, 2022, 04:52:02 am »
The tbi pump will not put out enough pressure/flow for an ls,as to your question,i think holley has tanks and/or pumps that will work.
Sent from my SM-G973U1 using Tapatalk
« Reply #2 on: February 21, 2022, 06:25:57 am »
25163473 60 psi rated pump @ 25 GPH will fit right on the 87 stock setup
Offline ehjorten
« Reply #3 on: February 21, 2022, 10:34:51 am »
If you want to spend hundreds of dollars, go buy a "purpose built" tank from one of the aftermarket suppliers. If you don't want to spend that kind of money, then just buy the proper pump and replace your TBI pump. It fits right in the sender unit with very little modification.
-Erik-
Offline jfkelley
« Reply #4 on: February 21, 2022, 10:40:47 am »
I think there some confusion I don’t have an TBI Sending unit or the 87 Tank ..I’m looking for vendors that sell the complete unit for my LS Swap into my 76 K10 Stepside
Offline ehjorten
« Reply #5 on: February 21, 2022, 01:10:41 pm »
Well, Holley sells a sweet little fuel tank for your truck for like $800. It gives you basically a stock tank with a fuel pump module and a separate fuel level sensor. Or you could buy a stock '87 tank for about $160, fuel pump module/sender for about $80, and an EP381 fuel pump for about $90. That is $330. You will have to address the different size fuel fill on the '87 tank to your side of bed fill, but that shouldn't be hard. You can also use the Corvette Filter/Regulator if you have a returnless system on your LS.
-Erik-
