Author Topic: Spark plugs  (Read 5849 times)
Spark plugs
« on: February 09, 2007, 06:45:00 am »
Anyone have good tips on getting spark plugs out of the head after the porcilin has blown out. I have already gotton to the point of pounding a 9/16 socket on, didn't work started colaspsing the plug metal. Next step is an easy out, but would like to hear any other ideas.
Offline DixieOffroad87
Re: Spark plugs
« Reply #1 on: February 09, 2007, 08:07:00 am »
i would say the ez out is probably your best bet. or im sure you have tried this but maybe an open end wrench.
Offline joesgarage71
  • Wrench
Re: Spark plugs
« Reply #2 on: February 09, 2007, 10:27:00 am »
I  hammered a bolt in the plug and spot welded on two sides once,worked good.
Steve
Edit;Socket on the bolt comes right out.
Edited by: joesgarage71 at: 2/9/07 7:28 pm
Re: Spark plugs
« Reply #3 on: February 09, 2007, 04:24:00 pm »
heat the spark plug steel shell with a torch....soak it with plenty of good penetrating oil too.
Re: Spark plugs
« Reply #4 on: February 09, 2007, 08:21:00 pm »
The welded in bolt crossed my mind, there is still quite a bit of metal left there.
Offline DnStClr
Re: Spark plugs
« Reply #5 on: February 10, 2007, 12:23:00 pm »
Harold, before you try removal, see if you can put a small screwdriver down thru the plug hole to see how far down the piston is. That way you know how far down you can pound in the EZ Out. Ya don't want to punch a hole into the top of the piston:lol
BTW- I hope none of the ceramic went down in the hole. Good luck. I hope you don't have the truck outside!
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Re: Spark plugs
« Reply #6 on: February 11, 2007, 07:57:00 am »
None of the ceramic went in, it just blew it out of the steel part of the plug. Truck is inside. Well I am going to try another type of easy out toady. Worked on it last night easy out I had din't work, the welded in bolt didnt work. Broke off more of the plug metal with the first one. Broke the second bolt off.Drilled it out and gave up for the night.
Re: Spark plugs
« Reply #7 on: February 11, 2007, 08:08:00 am »
you need heat! get that sucker hot and it will come out.
Re: Spark plugs
« Reply #8 on: February 11, 2007, 08:34:00 pm »
Wooo Hooo I got it out! Heated the head all around the plug, drove the easy out in, and she came out with a little encoragement.
